red filter for b/w
Discussion in 'Beyond the Basics' started by enigma, Jun 13, 2003.
  1. enigma
    enigma TPF Noob!
    Jun 13, 2003
    86
    When using a red filter, to make a nice blue sky look very dark with b/w film, do I set the light meter before or after I put on the filter? Or does it matter?
    Thanks
  2. metroshane
    metroshane TPF Noob!
    Apr 30, 2003
    615
    In my experience it doesn't matter a whole lot. But the thing with red filters is that it makes blacks look blacker and whites look whiter. I don't know that i'd necessarily make any sky look dark.
  3. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    4
    Pasco, WA
    If you are using a SLR or a digital you'd put the filter on and meter through it. No idea what you'd do for a hand-held light meter & something like a rangefinder camera though.
    Jim
  4. enigma
    enigma TPF Noob!
    Jun 13, 2003
    86
    thanks guys. I have seen pictures where they do this, and the red filter makes the blue in the sky turn very dark, and the clouds brighter. It will not wok on an over cast day, the sky needs to be fairly blue.
    thanks again
  5. dlc
    dlc TPF Noob!
    May 14, 2003
    293
    Indianapolis IN
    If you use an incident light meter, you will need to open the lens 3 fstops. If using the camera meter, it will meter through the filter.
  6. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    4
    Pasco, WA
    3 Stops! :shock:
    Wow, I had no idea it would be so much. Good to know info dlc, thanks for passing that along.
    Jim
  7. dlc
    dlc TPF Noob!
    May 14, 2003
    293
    Indianapolis IN
    Jim.....If it is a #25 red it is 3 stops. I was assuming that it was.
  8. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
  9. ranchman
    ranchman TPF Noob!
    Jun 25, 2003
    San Antonio. TX
    Another great thing the 25 red filter is good for is portraits or glamour shots. It sucks all redness out of the skin leaving it blemish free and very nice to look at and the prints are wonderful. It does require a faster film as you need to open up 3 stops but worth it.
  10. e_
    e_ TPF Noob!
    Jun 20, 2003
    177
    ...... itinerant ..........
    ...if the loss of 3 stops restricts your shutter speed options and the extra grain of faster film is undesirable, use a yellow filter (maybe a -0.5 stop loss):
    Nice affect on skin (portraits), separates the tones -- and gives a similar affect as red filter when used for landscapes
    e_
red filter photography
