Did you have a filter on your lens? You have some ghosting going on there. I took your image and cut out that section, mirrored and flipped it, and it is a perfect match to the bright green tree trunk to the right of the "ghost". It was pretty obvious before-hand, but I just wanted to check.
Ghosting is reflections of light bouncing back-and-forth within the lens elements, and filters usually enhance this. Whenever I take night shots with a lot of bright lights, I always take any filters off the lenses.
I did have a UV filter on the lens. I'll be sure to remove it before I do any more night photos. It did it mostly with the green light for some reason. Thanks for the input.
I take my polarizer filters off whenever I'm not shooting outdoors in sunny condition. They steal some light, so unless you want longer shutter speed, you probably don't want to keep them on when they aren't doing anything for you.Hmm, i never take off my UV filter or polarisation ones
