Reflective Material
Discussion in 'Commercial/Product photography' started by mikernak, May 8, 2008.
  1. mikernak
    mikernak TPF Noob!
    May 17, 2007
    8
    CT
    Ok here's the problem! I cannot get this stuff to reflect! it is Prismatic reflective material coated in a vinyl!
    [​IMG]
    It always shines from the vinyl!!!
    Anybody else ever shoot this kind of stuff... OR have any suggestions!?
  2. Shibby!
    Shibby! TPF Noob!
    Oct 10, 2007
    283
    Calgary, Ab. Canada
    I think the whole point is that the light has to be shining on it directly to reflect. If you are using off camera flash, it won't shine.
    Try putting a flash on your camera.
    (I may be wrong, but just offering a suggestion)
  3. mikernak
    mikernak TPF Noob!
    May 17, 2007
    8
    CT
    I'm desperate now, i've tried pretty everything under the sun. snooting, reflectors, flagging, polarizer over lens, don't think dulling spray will work (but trying tomorrow)!
    my last theory is hot lights... wysiwyg scenario!
    I did try your suggestion, with no avail. Thanks though!!!
  4. Jedo_03
    Jedo_03 TPF Noob!
    Mar 30, 2008
    328
    see the car at the bottom right...
    presume the front of the car is facing the guy...
    what if you turn on the headlights??
    Jedo
  5. Atropine
    Atropine TPF Noob!
    Nov 9, 2007
    128
    Sweden
    Well, the normal design of reflective materials is that they reflect most of the light back to where it came from. So polarizers and snoots and all other stuff won't help you much if you don't have the main source of light coming from your pov. Try some special arrangement with the flash shooting rigt beside the front lens, as close as you can. Moving back will also help you since the angle between camera-target-flash will get narrower.
  6. mikernak
    mikernak TPF Noob!
    May 17, 2007
    8
    CT
    I feel like a horses-arse!!! DULLING SPRAY saves the day again!
    I even thought of it, but thought it would block the light from bouncing back to the camera.
    It actually smoothes the light and makes it more uniform! Yahoo!!!!!!
    Thanks everyone for the suggestions! sometimes you have to just ask and then you get ideas! So i guess thanks for being there!
