Remind me, guys....
Discussion in 'Film Discussion and Q & A' started by Trainboy, Nov 29, 2007.
  1. Trainboy
    Trainboy TPF Noob!
    Nov 27, 2007
    7
    Canadian Pacific Railway headquarters
    Does 35mm film still have any advantages over digital, save for noise on ultra-long exposures?
    I'm disillusioned =(
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I think 35mm has higher resolution than (most) digital cameras.
    Isn't it something like 16 megapixels to equal the resolution of a 35mm frame?
  3. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    If it has more resolution is not the question. Are you going to be able to take advantage of that resolution is the question. It's going to get scanned at some point, and to really take advantage of the resolution, it needs a great scan. For me, it's second generation digital. I'd rather start with the product I'm going to end up with. If you buy a high end film scanner and control the process yourself, it might be worth it to you.
  4. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Yes there is an advantage. You can mess up more with your exposure and still get good pics. 5 stops of latitude instead of about 1.5....
  5. selmerdave
    selmerdave TPF Noob!
    Nov 30, 2004
    454
    Brooklyn, NY
    You're making an assumption that the photo is for digital use. If you were to end up with an analog product, wouldn't you want to start with an analog source?
    Dave
  6. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    He's comparing film to digital. He's not going to buy a digital SLR and then do analog printing.
  7. cigrainger
    cigrainger TPF Noob!
    Feb 2, 2007
    480
    I think so.. I still prefer the tonality of b/w film -- I don't feel you can capture it with digital. Price is still a huge factor. My $200 Canon 8600F scanner can scan 35mm negs much larger than the 6mp from my Pentax K100D. Considering I shoot with a Pentax ME-F, that plus 28mm, 50mm, and 135mm lenses cost less than the Pentax digital body alone by far. High ISO shooting also looks better on film.
    Obviously digital has its advantages over 35mm that for some people definitely make it more attractive. The ability to shoot away and edit later, and change ISO on the fly effectively simulates being able to change film every frame. From a cost standpoint, the initial buy-in is way higher, but you never have to pay for film or processing/chemicals.
    If you make wet prints, however, you can make much bigger enlargements with film and only get grainy. Looks much better than pixels if you want a bigger print from your digital.
    Why am I sitting here comparing 35mm to digital? :( Just shoot with what you like.
  8. selmerdave
    Nov 30, 2004
    454
    Brooklyn, NY
    His question was quite general, he didn't say anything about buying a digital SLR. I would say there are several advantages to film for those that appreciate it (to the OP - most are discussed in the hundreds of threads on this topic in the archives), and analog printing is one of them.
    Dave
  9. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    It's like comparing apples to oranges. Both are nice, so why limit yourself to just one? ;)
  10. Trainboy
    Trainboy TPF Noob!
    Nov 27, 2007
    7
    Because film up here in Canadia is expensive! :lol:
    Incidentally, I use a K-1000, don't get the best results, and miss my P&S digi. Yikes.
    My colours are always a bit off, a lot of the time grain is killing me, and (This goes against everything I've ever heard) my pictures have shockingly little exposure latitude. Highlights are blown out, shadows are unsalvageable black.
    I think I'm definitely a digital guy, seeing as I mostly work on the web, but I really have a soft spot for film, seeing as I learned on it. Lately, it's been letting me down...
    I'm going to blame my camera.
  11. selmerdave
    Nov 30, 2004
    454
    Brooklyn, NY
    Well of all the reasons to choose one or the other, that's *not* one of them. Exposure is exposure whether on film or digital, and you would probably do better in either medium if you took the time to learn to expose properly without "program mode". Slide film will teach you best and is quite inexpensive to have processed.
    Dave
  12. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    It comes down to this: an analog print from film > an inkjet print from digital.
