Removing a lens without turning camera off
Discussion in 'Nikon Cameras' started by krice300, Apr 15, 2013.
  1. krice300
    krice300 TPF Noob!
    Nov 12, 2012
    35
    I have read in the nikon manual that removing a lens without turning the camera off is no-no. I have been good so far but tonight I took off a lens and put a new one on without turning the camera off. Nothing seemed to happen but is there anything that may not be noticed right away that can damage any components?
    Thanks
  2. KmH
    Apr 9, 2009
    39,342
    5,303
    Iowa
    The electronics in the lens get their power from the camera battery. Removing the lens with the power on might cause a capacitor discharge power spike and fry some electronics.
    Static build up on you, and if you are or aren't grounded can cause a problem. That little spark of static can be 50,000 volts or more, which is hard on electronics designed for 5 volts.
    Might. Most times you won't have a problem, but it only takes once.
    There are to many variables - temperature, humidity, how dirty (and what kind of dirt) the camera to lens contacts are, and more.
  3. CaptainNapalm
    CaptainNapalm No longer a newbie, moving up!
    Nov 27, 2012
    796
    143
    Toronto, Ontario, Canada
    I've made that mistake many times, probably 20 I'd guess, with no problems so far. I just always forget to power the camera off when I'm in a rush to switch lenses, but I've gotten better.
  4. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    38,433
    14,199
    USA
    I've made that mistake hundreds of times. So far, so good. I TRY to turn off the camera, and I've become pretty good at it the last few years, but the first seven or eight years, I was terrible about forgetting to turn off the camera. I think the concerns about it are overblown, but that's just my opinion. No data, just hundreds of screw-ups and no fried electronics...
    • Like Like x 1
  5. DCerezo
    DCerezo TPF Noob!
    Jan 30, 2013
    265
    8
    Long Island, NY
    Hmmm I had no clue that this was even an issue. I never turn off the camera to swap lenses and out of the 4 SLRs I've owned... Not one issue. I'm going to have to agree with Derrel on this one.
  6. krice300
    krice300 TPF Noob!
    Nov 12, 2012
    35
    Thanks guys. I'll still try to turn off the camera but at least I won't be as worried if I forget
  7. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    Might or might not matter. Easy enough to get into the habit of turning the camera off. In 8 years of using digital slr's I've never not turned the camera off. I also turn off any mounted flash before removing it from the camera.
    In that time I've also never had a lens or camera failure.
    • Like Like x 1
  8. DorkSterr
    DorkSterr No longer a newbie, moving up!
    Jun 28, 2011
    831
    70
    Toronto
    Same here I've done it countless of times and not an issue. I even pull out the battery to charge it without turning it off. I could probably love with my camera glued to the ON position.
  9. jrizal
    jrizal TPF Noob!
    Apr 15, 2012
    572
    31
    Los Angeles, CA
    You won't want the one time big time scenario to happen do you? How many times have you crossed the street or driven the freeway and nothing happened. It only takes one time. It's good to know that if you forget to turn it off, nothing happens most of the time. But how hard is it to really turn off your camera?
  10. Trever1t
    Trever1t Been spending a lot of time on here!
    Dec 30, 2010
    9,228
    2,616
    San Jose, CA
    I did it one time and boom! Cost me a $371.00 repair bill :(
    just kidding, everyone makes the mistake at least once!
  11. DarkShadow
    DarkShadow Birdographer Supporting Member
    Mar 24, 2013
    7,168
    3,369
    Connecticut
    I forgot a couple of times my self but I forgot more often to shut it off when putting it away back in my camera bag and essentially its in standby mode for a day or two maybe longer. Opps where is the charger.Just kidding ,the battery drain is almost non existent unless shutter button gets pushed some how.
  12. SCraig
    SCraig Been spending a lot of time on here!
    Nov 12, 2011
    6,195
    2,283
    Nashville, TN
    It is always a good idea to turn the camera off before removing the lens, if for no other reason than when you remove the lens you are changing polarity and shorting out the CPU contacts on the lens. The lens gets power from the array of contacts on the edge of the lens mount. When you turn the lens the pins are changing polarity and signal to values they weren't designed to handle. It may or may not cause a problem, but if it does it is going to be an expensive problem, one that there is no reason to risk.
    Like most I've done it many, many times with no problem. I do try and remember not to do so since there is the possibility of ruining a lens but it's an easy thing to forget to do.
    • Like Like x 1
changd nikon lense without turning off
change lens without turning off camera
one camera one lens photographers
removed a lens with the power on
removing lens off nikon without power off
took lens off camera and didnot turn it off
took my lens off without turning camera off
toolk off the lens without tiurning off the camera
turn camera off to change lens
what will happen to my lens that i removed without turning my nikon d7100?
