Removing CPL
Discussion in 'Photography Beginners' Forum' started by Jon0807, Jan 20, 2008.
  1. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    This might be a silly question but I'm having a hard time removing my circular polarizer when I have it in front of a UV filter or a step up ring. I just can't seem to get them to separate easily without getting my greasy finger prints all over the place. Does anyone have any tips or tricks? I've tried screwing them in as lightly as possible but they seem to always tighten when I adjust the polarizer.
    Any help would be great and it would save my hands from cramping. Thanks in advance!
  2. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    I have this problem all the time too. I haven't really found a good solution yet, but I hear that graphite helps a lot (haven't tried it yet, but it's on my shopping list...).
    Don't waste your money on those plastic filter wrenches, they don't work.
  3. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    I have the same issue from time to time. Usually I'll try to put all 5 fingers on the filter and then just twist it for all you're worth. I've heard that if you only use 2 or 3 fingers you can put pressure on the filter and make the metal ring turn SLIGHTLY oblong which makes it more difficult to twist. So using all 5 fingers eliminates that.
    Also, not sure you'd need the UV and CPL filter together. Might not be worth the headache.
  4. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    I usually keep the UV filter on just to protect the lens when I take the polarizer off when I switch lenses or the step downs on f stops are unwanted.
    I've been playing with it all night and noticed that if I use a very light touch with more than 3 fingers, it comes off with very little effort. It amazed me each time it happened. I would twist with all my might till my fingers went numb. Then I would just lightly turn and off it came...go figure lol
  5. Rhubarb
    Rhubarb TPF Noob!
    Dec 16, 2004
    286
    Roaming the globe
    I have came up with the theory (because none of my other filters get jammed on like my CPL's) that when I rotate the CPL the same way as you tighten the filter, it gets it on real tight - especially as my CPL is pretty thin - I noticed that my fingers were on both the front and rear 'elements' when I was adjusting it.
    My fix is to rotate it the opposite way - and I have no probs with getting it off now. Just need to be a wee bit careful that you don't rotate the CPL off.
how to remove a cpl filter
how to remove cpl filter
how to take off cpl filter
lvshi cpl
lvshi cpl filter
lvshi cpl filter review
lvshi filter review
lvshi filters review
open a cpl filter
remove cpl filter
