Removing lens on M3
Bongo Najja
Has anyone had problems removing the lens on the Leica M3? I pressed the button and turned the lens counter-clockwise, but it just won't release. I'm in a slump. Any advice will be appreciated. Thanks.
Are you holding the button down as you turn the lens?
Get a much larger hammer, that always works.
Yes. I've tried everything with that button. Seems like the lens is jammed. I may have to take it to be repaired. Or, I could just stick to one lens, but I would like to get a 90mm for portraits. Thanks for your reply.
What less is it ? Is it an LTM with adapter
Sent from my SM-G903F using Tapatalk
It's a 50mm Summicron, M Mount. It appears to be jammed. There's no adapter.
Are you sure you are pressing it right in ? I have 2 M Leica's and have never heard of this problem before
Try putting clockwise pressure on the lens before pressing the button then turn anticlockwise
Well, what do you know! That worked!!! Thanks a million, my friend!!! Now, I can put a bid in on that 90mm lens I've been wanting. Thanks again.
Yes, pressed all kinds of possible ways. Nothing.
GSGary suggested I put pressure on the lens while turning clockwise then press the button and that worked. I got it off. Thanks for your help, for it's much appreciated.
Compur, I'm not sure if I sent the message to you correctly letting you know I was able to remove it after GSGary suggested I put pressure on the lens while turning it then press the button, which worked. I wanted to make sure you got this message to thank you for your help, which was most appreciated (reason I'm sending it again)
No problem
You're welcome. Glad you succeeded!
