Another easy way is dup the image into another layer so you have two of the same image. I would mask out the two people and then blow them up just a tad so they cover up the shadows. Then flatten it and boom your done.
I assume you have a larger image to work with. In any case, try this approach:
1. Select a piece of the background about like this:
2. Copy that to a new layer (Ctrl+j), move it over to cover the shadow behind the man. Stretch the copied section a bit vertically.
3. Put a black mask on that layer and paint with a small, white brush to reveal the new background and cover the shadow. Use the same technique for the shadow behind the woman.
