Josh66
- Joined
- Oct 31, 2007
- Messages
- 14,593
- Reaction score
- 1,239
- Location
- Cedar Hill, Texas
- Can others edit my Photos
- Photos NOT OK to edit
So that rules out bromide drag and just leaves agitation (I think).
Dunno, but if it is bromide drag, it's not possible that he was using Rodinal, because there's no bromide in Rodinal (or AFAIK any other stand developer). Nor would surge marks make sense, because you barely agitate it.What developer is the OP using? I don't believe s/he has mentioned it (if it was mentioned, I missed it).
So probably something typical like D-76 or whatnot.
Guess not *shrug* Surge marks still sounds strange if he is being really gentle though. They are also just so neatly traced out.
I use a ton of Rodinal. Check out my Flickr stream if you don't believe me - you'll notice that the Rodinal set has nearly twice as many photos as any other developer set. Not "a lot", but I don't put everything I shoot on Flickr, and I have a lot of private stuff.
The less diluted the developer, the more it matters how you agitate. 1+25 requires very gentle agitation. A 1+100 stand, on the other hand, I agitate the **** out of it for a solid minute, then don't touch it for an hour.
I agitated during development and fixing with more vigor, seemed to do the trick. I'm assuming it was a fixing issue that is now fixed (bad pun).
True.
Well, I didn't say that it happens every time. Just that I've seen it happen, and it seemed to be from too little agitation.I use a ton of Rodinal. Check out my Flickr stream if you don't believe me - you'll notice that the Rodinal set has nearly twice as many photos as any other developer set. Not "a lot", but I don't put everything I shoot on Flickr, and I have a lot of private stuff.
Thats strange because this shot is 1+100 5 gentle agitations then put in fridge for 1 hour
