Replacement Lens Caps?
Discussion in 'Beyond the Basics' started by Johnathan, Feb 14, 2005.
  1. Johnathan
    Johnathan TPF Noob!
    Feb 14, 2005
    32
    Arkansas, US
    I just got a Pentax K1000 second hand. The camera is great, but it is missing some of the lens caps. I know with how my luck goes, I'll have them scratched in no time flat.
    I have with it a 50mm 2.8 lens that needs both front and back caps. It says on it "SMC Pentax-A". I'm not sure what that means. I also have a Takumar 70-200mm 5.6 that is missing just the rear cap.
    Any idea where I can find replacements for these?
    Thanks!
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Front caps are easy to find. The front of the lens should have threads in one of a few standard sizes. 49mm, 52mm, 55mm, 58mm etc.
    The rear cap on the other hand will have to match the mount of your camera/lens. If you have a camera shop around that has used equipment, they should have a few, Pentax K1000 was fairly popular.
    Check the big photography stores sites like Adorama. Use the link on the bottom of this page.
    If not, E-bay should turn up anything you will need.
  3. kfoster
    kfoster TPF Noob!
    Dec 25, 2004
    148
    Allentown, PA
  4. Johnathan
    Johnathan TPF Noob!
    Feb 14, 2005
    32
    Arkansas, US
    Wow, thanks guys! Looks like I can get everything I need from BocaPhoto. One question though: They have a generic front cap that says it is 52mm. Do you think that is what I need for my 50mm lens? They cap is snap-on, so I'm kinda hoping that extra 2mm is for the spring loaded snap things. I did measure my lens assembly, and it is exactly 50mm in diameter.
  5. Kodan_Txips
    Kodan_Txips TPF Noob!
    Feb 6, 2005
    99
    I think the K1000 took 49 mil filters, so would need a 49 mil lens cap. It should say somewhere on the ring surrounding the front element of the lens.
    A symbol like an O with a backslash through it, and a number.
generic lens caps replacement
k1000 lens cap
pentax k1000 55mm lens cover
pentax k1000 lens cap
pentax lens cover for k1000
