replacement mercury battery options (Canon Canonet 28)
Discussion in 'Photography Equipment & Products' started by aNgLiaM, Sep 2, 2006.
  1. aNgLiaM
    aNgLiaM TPF Noob!
    Sep 2, 2006
    21
    Yankton, SD
    hello,
    i am n00b to photography. my mom recently gave me her Canon Canonet 28 35mm camera. it still had a PX-13 mercury battery that was starting to corrode, so it obviously needs to be replaced. from what i've read, it looks like rather than having the camera recalibrated for a higher voltage battery or using a battery that isn't an exact match and will cause voltage issues (such as a PX-625 1.5volt), it is a better option to buy a MR-9 Battery Adapter and a silver oxide 76 cell.
    my questions are: is this the best option for replacement and, if not, what do you recommend?
    thanks in advance,
    Justin
  2. DeepSpring
    DeepSpring TPF Noob!
    Jul 12, 2006
    1,451
    Los Angeles
    I recently got one of those too from goodwill. The guy at ritz put in a varia 625 u battery. Sadly there is a light leak in my camera tho that needs fixin so the roll was ruined. Hope you have better luck.
  3. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    A direct replacement would be a Wein ( mercury equiv. ) which is 1 .35 volts. They are available at most photo stores. The other option which I have heard of but not tried is, find a hearing aide battery that is the same size and voltage. On the back of hearing aide batteries, there are 4 holes, to let the air in, put a drop of super glue over 2 of the holes so they last longer and you should be good to go.
  4. aNgLiaM
    aNgLiaM TPF Noob!
    Sep 2, 2006
    21
    Yankton, SD
    thank you for the suggestions, does anyone else have anything to add?
battery canon canonet 28
battery for canon canonet 28
battery for canonet 28
canon canonet 28
canon canonet 28 battery
canonet 28 battery
canonet 28 battery replacement
canonet 28 battery type
canonet battery
replacement battery for canonet 28
