Replacing foam in Canon lens cases
Discussion in 'Film Discussion and Q & A' started by Valethar, May 15, 2010.
  1. Valethar
    Valethar TPF Noob!
    May 5, 2008
    101
    Puyallup, WA
    Greetings,
    I've several Canon lens cases (C & D models) that need to have the foam replaced. The cases themselves are in great shape, just the foam is shot and literally disintegrating. I'd hate to have to ditch them if I can replace the padding instead.
    I can probably pick up foam from a craft store or someplace that does upholstery if needed. A quick google search found one post from a few years ago that mentioned some types of foam releasing a gas that was bad for the lens coatings (polyurethane I think), but otherwise no real useful info.
    Any suggestions?
  2. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,040
    509
    L.A.
    I've never used it for your purpose but I would try a product called Foamies.
    It's a foam sheet in various thicknesses and colors, with or without
    adhesive backing. It's often sold through arts & crafts type retailers. I get
    mine at a local fabric/craft shop. I've used it to replace missing rubber focus
    rings on lenses, camera case lining, camera light seals, even for fixing leaky
    bellows. It's easy to work with and pretty cheap too. I've been meaning to
    try making a whole camera case out of the stuff when I get around to it. It
    has a nice feel to it and cuts easily with an Exacto knife, etc.
    You can get an idea of what's available here:
    sheets items & other from ConsumerCrafts
  3. Valethar
    Valethar TPF Noob!
    May 5, 2008
    101
    Puyallup, WA
    I'll give that a look.
    Thanks!
lens case foam
