Resize before or after color adjustment?
Discussion in 'Graphics Programs and Photo Gallery' started by Zephyr7, May 12, 2007.
  1. Zephyr7
    Zephyr7 TPF Noob!
    May 12, 2007
    Hi. I was wondering if techniques like adjusting color, brightness, filters etc are best applied before or after reducing an image's size. Thanks!
  2. KaraM
    KaraM TPF Noob!
    Jan 16, 2007
    54
    Texas
    I do all of my adjustments before I resize - especially if it's portraits for others.
  3. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    well, for most things you mention really it does not matter. However you can save a lot of time later when you do it all before resizing ... just in case you need the original size at some point with all the changes applied ;)
    Sharpening should always be done on the final size though.
  4. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    It doesn't matter at all. On full weddings I adjust and then resize, and on portraits (bridals etc) I crop and then adjust. It shouldn't make any difference.
  5. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Well i'm with elsapet on this. the only thing I make sure I do last is sharpen. I'll sharpen by different amounts depending on the size of the image.
  6. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    EOS-
    Watch out for sharpening. It MUST be the last step before print. On most web images I bypass that step as it halos. But when I send out photos for reprint, I crop and then blast it with KPD unsharp.
  7. elsaspet
    elsaspet TPF Noob!
    Dec 14, 2004
    4,054
    37
    Dallas
    Oh nevermind. I just reread............duh. Sorry.
  8. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
  9. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    I might work differently from others but I do an initial (light) sharpening along with any global changes (temp, color, brightness, exposure, etc) before I do any pixel level changes. After pixel level changes, I do snapshot then slight area sharpen (USM with tiny radius, 0 threshold). Then save as PSD.
    If I am going to print I size and do flnal area sharpen, smart sharpen, convert profile, convert to 8 bit, save as jpeg.
    If I am going to display on web, I reduce size, convert profile to sRGB, convert to 8 bit, resharpen and save as jpeg
crop picture before or after adjustments
editing after resizing
resize photo before or after editing
sharpen before or after crop
should photography be resized before editing or after editing
