Resizing in Photoshop Elements 7
Discussion in 'Photography Beginners' Forum' started by lvcrtrs, May 19, 2009.
  1. lvcrtrs
    lvcrtrs TPF Noob!
    Dec 18, 2008
    606
    Pennsylvania
    In Elements 3 I could have sworn an option for resizing was pixels. I would put 800 in for the long side of the picture (so it would work in my digital frame or for here). In Elements 7 I don't see it. The original information in the Image Size box uses pixels but the box you make changes in has several other options (%, inches, cm, mm, points, picas and columns). Any help for me. TY
  2. OldClicker
    OldClicker TPF Noob!
    Nov 29, 2008
    194
    Mundelein, IL USA
    I have Elements v6, but I think they are nearly the same.
    I got to Image>Resize>Image size and the box pops up.
    In the box, the top section is in pixels (or percent) and you make the changes there. If it does not allow changes there, click the Resample Image check box at the bottom (I use Bicubic, but I don't know why).
    TF
  3. KmH
    Apr 9, 2009
    40,744
    5,588
    Iowa
    Look under Edit>Preferences?
  4. lvcrtrs
    lvcrtrs TPF Noob!
    Dec 18, 2008
    606
    Pennsylvania
    The resample image box worked. Thanks. It is the little things in life that can make or break you. Glad so many people have been down the road before me.
    D90, F5.6, Exp 1/100, ISO 500, +.3, 270mm, spot meter (all that info makes it look like I know what I'm doing-tee hee)
    [​IMG]
