I've made a decent 8x10 from a 2Mp camera with a JPEG file size around 500K to 600k but that's about the limit and it depends on the pic and subject matter.
I used to use a Nikon D1 (3MP) and we routinely printed 8x10 from them. You need to get good exposure and the best cropping you can - in the camera.
Then crop at 300 dpi. There's not much value gained in going beyond 300 dpi. The reason for that being the human eye can only see around 300 not more than that. Most printers are therefore made to print at 300 dpi and normally discard any file info in excess of that.
The one common exception to this is the Fuji Pictograpghy series which prints at 400 dpi.
You're not alone there. A lot of people still struggle with the two concepts of pixels and dots. I can't explain it - I just "understand" it. Or rather accept it.
Printers use dots, hence dots per inch (dpi). Electronic images use pixels per inch (ppi). If I remember correctly 2ppi=1dpi.
So now that we have you seriously confused do a mental erase and remember if you are going to print a hard copy then you'll want your final image to be length X width @300dpi.
So you download the camera. Open your imaging software (PhotoShop). Select the crop tool, specify the size (8inches x 10 inches for example), specify the dpi at 300 and make your crop. Do you image management (color correction, brightness/contrast, etc.) and save the image. Now you're ready to print.
ah... now something is bad... photoshop asks me the resolution in PPI, not DPI... so, if you said 2ppi = 1 dpi, am I supposed to set it to... 600dpi? ???
The image size is now 82.4 M !!! is that 82.4 MB?! wtf?!
now I kind of understand rangefinder... but cant I just download some... lets say 3MP photos from my camera, edit them in photoshop (brightness, colors, etc, NOT the size), save them, take them to the shop and tell the guy to make 'em 8x10 prints? is it necesary to resize them ?
damn, I'm kind of starting with digital printing...
The confusion gets deeper. Printers use DPI and LPI.
DPI is the resolution of the printer, and LPI (lines per inch) refers to the way printers reproduce images, simulating continuous tone images by printing lines of halftone spots. The number of lines per inch is the LPI, sometimes also called line frequency. You can think of LPI as the halftone resolution.
The Abreviation DPI gets used generically for resolution though. PPI is actually LPI x 1.5, but since most of us are lazy and don't want to do that math, we just do LPI x 2 and be done with it. Most photo labs print at 150 LPI, which would be 225 PPI (DPI, or whatever you want to call it ), but 300 has become lazy standard.
Ok, in answer to your last question, you should resize them yourself, to ensure that they look just how you want. If your images are not of the 8x10 aspect ratio, they will either stretch or squish to fit, or the printer will crop them, neither of which is desireable. If you have to crop, at least do it before you print so that you can control it.
Or you can do what I do which is not crop and just print 8x12s and buy custom frames
