Reversed Lens or Super Macro
I was going to start a new thread, but I discovered that there was a theme thread for this...
Fixed the links. I'm not sure if these are the same ones I had originally posted, but I think they probably are (or close enough anyway).
Here's a couple I took last night!
#1 Flashlight
#2 Tattoo Goo
I used a Tamron AF28-80mm F/3.5-5.6 to take these photos; using it backwards. It gives you a macro! :lmao: Learned this from a friend.
Have you tried it before? :D
Also, I've done this little trick:
You can put higher f-number on the lens, but adjusting f-number first, holding down the dof preview button and taking the lens off the camera at same time, now the f-number selected will stay on the lens after you remove it. If you remove the lens normally lens will be wide open and naturally focused area will be really(too) small.
6. Did not use the DOF button:
7. Didn't use the DOF button on this one, either
8.
I still don't get how you could hold your camera so far away and still get sharp reverse macro pictures but I guess my lens is just different or something lol.
here are some of mine:
#1 I guess f/11 was still too wide for reverse macro pics.
#2
#3
#4 I used a much longer focal length for this one.
#5
#6 and no this is NOT a real Rolex lol. I hate when my lens cast a huge shadow when taking close up pictures a macro flash would have been nice ^^.
#7
A theme thread on photos taken with the reversed lens has existed for long, so I merged the newly started with the existing one.
Bringing this (sorta) dead theme back!
Posting 2 because they go together, lol.
My new camera:
