RFID
Discussion in 'General Gallery' started by Josh66, Mar 3, 2009.
  1. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    The first two are at 4:1.
    [​IMG]
    [​IMG]
    I tried to clean the dust off better before shooting, but it was almost impossible. The strands of wire you're seeing are only about .001" in diameter.
    The set-up:
    (Just noticed - only one of the lights is on in these.)
    [​IMG]
    4
    [​IMG]
  2. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Just noticed that #2 looks like a plank of wood from far away... Kinda cool.
  3. jv17
    jv17 TPF Noob!
    Aug 7, 2008
    600
    nice shots.. love it..
  4. Mgw189
    Mgw189 TPF Noob!
    Dec 31, 2008
    838
    Binghamton, NY
    very cool I love my reverse mount macro ring as well.
  5. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Thanks guys.
    It's actually a macro coupler, not a reverse mount. It's a 70-200mm f/4L and 50mm f/1.4 mounted face to face.
    edit
    I shot these at f/5.6. I should have stopped down more, a lot more. I didn't want them to be soft so I kept it at 5.6.
    I was just looking at some older pictures with the same setup shot a f/32 - they're way sharper than these...
    I'll try again tomorrow. Wasn't expecting the DOF to be so microscopic at f/5.6 (f/32 doesn't buy you much more either, but every little bits helps).
  6. timethief
    timethief TPF Noob!
    Jan 28, 2009
    909
    19
    nice shots.
    i like the contrasts in 3 and 4
    post more.
  7. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Thanks
    I will - as soon as I see what's new on TPF (just got home from work) and finish my tea. :D
  8. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Used a blank DVD as the background on these.
    (5, 6, & 7 are 4:1)
    5
    [​IMG]
    6
    (almost the same as 5 - exposed 3 stops longer)
    [​IMG]
    7
    [​IMG]
    These three are pretty similar to each other... I just couldn't decide which ones to post, so I'm posting the 3 best.
    8
    This one (even though it is a failure) was pretty cool, I think.
    It's at 16.6:1. I didn't realize that the image would not fill the frame at that magnification...
    Every aspect (even getting it in the frame) of this shot was insanely difficult.
    I had it sitting on a stack of DVDs, adding or removing discs to focus. At this magnification, the thickness of one disc would throw it outside the focusing range - I had to shim the disc with sheets of paper to focus (getting it back in the frame after each sheet...). I do not have a focusing rail, now I understand how they could be a huge benefit.
    Shifting your weight on the floor makes the camera shake...
    Anyway, here it is... I guess I'm just posting it to prove that I tried...
    [​IMG]
    Just for reference - this thing is about 1mm square, maybe 1.5mm square. You can see how small it is in #3 & 4.
    EDIT
    Just a quick reference shot:
    [​IMG]
  9. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    I might try to combine 5 & 6. The board is exposed better on 6, but the gold parts are blown out.
