Riddle me this...
Discussion in 'Graphics Programs and Photo Gallery' started by brent1971, Aug 12, 2008.
  1. brent1971
    brent1971 TPF Noob!
    Aug 12, 2008
    4
    Atlanta, GA.
    I've been playing around with some different techniques trying to get the effect that this photog has in some of his images. Particularly like the Coors image with people washing the car in "G1" Any ideas?
    http://www.georgefulton.com/
  2. Trenton
    Trenton TPF Noob!
    Aug 11, 2008
    22
    I wish I knew too I found a tutorial once but now I have misplaced it. It might have to do with saturation or something i dont remember...
  3. brent1971
    brent1971 TPF Noob!
    Aug 12, 2008
    4
    Atlanta, GA.
    yeah it definitely has to do with a combo of saturation, contrast, curves and sharpness... I just can't seem to get there.
  4. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    try lucisart.com
    very pricey software
  5. brent1971
    brent1971 TPF Noob!
    Aug 12, 2008
    4
    Atlanta, GA.
    Yep! That's definitely what he's using. Thanks for the help!
  6. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    The Lucis plugin will produce a similar effect if used correctly. But no one worth their salt in post uses it. They do it by hand. If this is the same guy who's done the other Aisics ads, I can just about guarantee he doesn't use that plugin.
    It's all about layering unsharp masking...the actual USM, high pass layers, etc. The rest is done literally by hand.
  7. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    It's local contrast manipulation, in particular tonemapping. Lucisart, Photomatix, and others offer software that make it pretty easy. I think there's even some tonemapping shareware out there.
    Controlled lighting goes a long way to making the effect look good even if there's going to be a lot of tweaking in processing.
    Some of the following things can be done with Photoshop (I use CS2, CS3 probably has more options) to control contrast like this. None of them really get there by themselves, but in combination they can get pretty close.
    Shoot raw and instead of going with the default tone curve switch to the original linear curve (is that an oxymoron?).
    Low percentage, high radius unsharp mask on a luminosity blend layer.
    The shadow/highlight filter (which is actually under Image->Adjustments I think).
  8. brent1971
    brent1971 TPF Noob!
    Aug 12, 2008
    4
    Atlanta, GA.
    That helps a lot. I'm going to play around with for a while and see what I come up with. Thanks!
