rings and circles??
Discussion in 'Digital Discussion & Q&A' started by nrois02, May 3, 2009.
  1. nrois02
    nrois02 TPF Noob!
    Feb 10, 2009
    324
    Boston
    so ive been having these problems in light thats around me and i was wondering if getting filters would help get this problem to go away. also im not using a lens hood but maybe that would help a little too. let me know thanks!
    here are some pictures to describe what troubles im having.
    [​IMG]
    [​IMG]
    and i dont even know what happened here all i know is that there was a lot of light due to the cop pulling up to me. and info?
    [​IMG]
  2. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    its lens flare, stop pointing the camera directly at the light source or bright light in general, a hood can help but not in the case of headlights facing you, the extra light is bouncing around inside the lens causing the condition. H
  3. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    No, any filter, including the supposed "UV protection" filters, will only make it worse. Also, a lens hood wouldn't help in this case as the source of the lens flare is in the picture. Hoods only block light that is outside of the frame.
  4. nrois02
    nrois02 TPF Noob!
    Feb 10, 2009
    324
    Boston
    ok thanks for the help. what is the purpose of getting filters then? ive never really been into it but my friend is and he says there good but never told me why
  5. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    Some lenses just cause flare and ghosting when pointing into light sources. Some lenses are very good at handling this, some aren't. Nikon's 18-55 kit lens, for example, produces absolutely no flaring, but the 35mm f/1.8 has a bit a flaring issue.
    There's nothing you can do about it but try to clone them out.
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Filters are for protection. But they (like every piece of glass) create a reflection. These reflections are very dark <4% of the light for the cheapest filters, and <0.5% of the light for expensive ones. This means the reflections are never noticed unless you get to a very high contrast situation (bright sky with a blown-out street lamp as in your example). The cheaper the filter the nastier the reflection. The nice expensive multi-coated filters are good enough that the flare is completely gone and only a small ghosting may remain of a really bright light source.
    Filters are not the solution. Multicoating antiglare on the lenses is the solution. This is not an easy process though and which is why many expensive lenses and sunglasses comes with an extortionate price tag. The coatings need to be precisely applied and baked on each element in an almost perfect vacuum.
