Rule of Thirds
Discussion in 'Photography Beginners' Forum' started by HailttRedskins, Apr 3, 2008.
  1. HailttRedskins
    HailttRedskins TPF Noob!
    Mar 5, 2008
    154
    Northern Virginia
    I've read into it a bit, and have seen about 5 examples, I was wondering if someone could post up a couple that they have taken using the Rule of Thirds so I have a better feel.
    Thanks :thumbup:
  2. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
  3. HailttRedskins
    Mar 5, 2008
    154
    Northern Virginia
    Well, I have two photographer friends, both are excellent in what they do, I showed them both this image, the one said it is, the other said it is somewhat, could you let me know what you think.
    Thanks
    [​IMG]
  4. JerryPH
    Oct 14, 2007
    6,111
    15
    [​IMG]
    I don't know about your photographer friends, or if they even know what they are talking about, but if you divide your picture into approximate 3rds, its very clear it is NOT following the rule of 3rds.
    Doesn't mean its a bad pic. Just means your subject is in the center, not in the other sectors identified as a line that intersects a sector in the thirds. Its following the rule when you place the center of your subject on any of the points where the lines intersect. Thats all!
    This is closer to following the rule of thirds:
    [​IMG] [​IMG]
    Does it make sense now? :D
  5. Sirashley
    Sirashley TPF Noob!
    Mar 26, 2008
    474
    17
    Broward, FL
    Think of the rule of thirds like a rule in the Matrix... Sometimes it can be bent, sometimes it can be broken... It just depends on your subject and depends on what works... For the most part, the rule of thirds will be your best bet... But every so often, you'll see a subject and frame a shot, where you are better off not using the rule of thirds... Of course, I'm an amateur, and that's just my opinion...
  6. HailttRedskins
    Mar 5, 2008
    154
    Northern Virginia
    Oh okay, and I see it a little better now.
    I have photoshop, is there some kind of tutorial I can have to create a rule of thirds line graph, or whatever it is called exactly, that way I can use it a fair amount.
    So basically I don't want the object in the middle box, or at least not the majority of it?
  7. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Jerry while your information is correct, it's a bit disconcerting that your image examples do not show the thirds lines correctly.
  8. JerryPH
    Oct 14, 2007
    6,111
    15
    I know Matt, those were literally hand drawn in like 3 seconds flat. It was for example purposes only... they did their job. ;)
    You will have to excuse my lack of precision... lol. :D
  9. Unreal Tuner
    Unreal Tuner TPF Noob!
    Apr 4, 2007
    84
    Across the bridge from D.C.
    HailttRedskins...we are near the same area. Are you on any car forums as well?
  10. HailttRedskins
    Mar 5, 2008
    154
    Northern Virginia
    I'm on VADriven and NovaStreetForums
    -EDIT-
    On VADriven I'm Mr. Photography - I just joined there
    NSF I'm HailttRedskins - Forum is dead for the most part
  11. Unreal Tuner
    Apr 4, 2007
    84
    Cool i'm on both myself, but NSF never has anything going on.
    VaDriven - Acuratuner00
    Maybe i'll see you around sometime. :cheers:
  12. LisaK24
    LisaK24 TPF Noob!
    Jan 29, 2008
    136
    Spain
    some DSLR's have a compositional grid feature that can be turned on. but you have the XTi, like me, and I don't think our cameras have that feature.
    but you could also make your own rule of thirds grid on your LCD monitor if you have one of those transparent plastic covers. just use a sharpie or something.
    but really, just try to imagine the grid everytime you look in the viewfinder. the more you keep it in mind, the better your compositions will be :]
rule of thirds mickey mouse
ernest haas does follow rule of thirds
how to make rule of thirds graph
photography rule of quarters rule of third
pics of rule of thirds mickey mouse
rule of 3rds graph
rule of 3rds photography
rule of thirds without the tic tac toe graph
violate rule of thirds
