rule of thirds
Discussion in 'Photography Beginners' Forum' started by choudhrysaab, Jul 13, 2009.
  1. choudhrysaab
    choudhrysaab TPF Noob!
    Jul 11, 2009
    667
    Toronto, Ontario. Canada
    Question ... should every picture have the "rule of thirds" applied to it or is there timing/location when its only best suited???
    (i hope you guys know what i'm talking about) =)
  2. Restomage
    Restomage No longer a newbie, moving up!
    Jul 3, 2009
    517
    25
    Fort Collins, CO
    Generally I would say yes the Rule of Third's should be applied to almost every photo, the only exception I can think of some forms of portrait photography.
  3. Clawed
    Clawed TPF Noob!
    Apr 29, 2009
    426
    20
    Arizona
    Not at all. The rule of thirds is certianly NOT an absolute, and you can get great composition without applying the rule of thirds. If you use a square crop, the viewers attention will gravitate to the center of the frame, so the r.o.t. is not always suited for this crop. Also, a subject that displays symmetry can sometimes be placed at the center with no problem. Basically, the rule is used to create tension in the photograph, and often results in a more 'meaningful' composition. Use it as a guideline, and you will definitely find it's a good place to start when thinking about composition, but after a while, you will get a better feel for what works and what does not compositionally.
  4. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    The Rule Of Thirds is just one compositional "rule" that you can use when composing a shot, but you don't have to use it. Depending on the subject and what you're trying to do, even a centered subject can work out fine.
    I think what's more important is that you actively think about what you're seeing when looking through the viewfinder and physically move around until you get the shot you are looking for. Be proactively creative before you hit the shutter release.
  5. choudhrysaab
    Jul 11, 2009
    667
    Thank you guys ... your input is much appreciated!!!
    its been just two days since I've registered and I've already learned so much =)
  6. Dylan-Fishman
    Dylan-Fishman TPF Noob!
    Jun 2, 2009
    264
    If there is stuff in the background then I would use the RoT's. If there is a blank background feel free to center. That is my personal observation.
  7. Baaaark
    Baaaark TPF Noob!
    May 27, 2009
    414
    North or South Pole... it depends
    I don't think so. Try some shots with it, and without, and some times the ones without look better.
    Especially when you're trying to get symmetry.
