Rust in a darkroom??
Discussion in 'The Darkroom' started by btooomayers, Mar 10, 2008.
  1. btooomayers
    btooomayers TPF Noob!
    Mar 10, 2008
    Hi,
    I'm am considering setting up some non-photography equipment in a darkroom that is shared with a standard photo-developer station. The room smells strongly of developer (acetic acid?) and I am wondering if I need to worry about steel surfaces rusting with the develper fumes. Is this typically a problem in Darkrooms? I have done some internet searches on corrosion and darkrooms, but the only definite thing I've found is that sink drains can rust.
    do metal items that don't come into direct contact with the developer rust?
    Thanks!
    -BTM
    (just realized that I posted this originally in the wrong forum, appologies for the repeat)
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    check your other post regarding the same question
  3. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    This is where it belongs but you should post only once.
  4. btooomayers
    Mar 10, 2008
    Sorry about the double post. >.<
    I am thinkng of putting some photolithography equip in the room. I want to convert the darkroom into a "dirty" cleanroom for semiconductor fab. But, I share the space with other users who will be using it for developing while I am not there.
    The equip is like an enlarger: litght source, shutter, mirrors. It will never get direct contact with liquids, and I will cover it with plastic when I am not there. Have you ever noticed things rusting in a 1-3 month period if they are never contact liquids?
    -B
  5. Hertz van Rental
    Hertz van Rental TPF Noob!
    Nov 8, 2004
    16,728
    45
    Where am I now?
    Without proper ventilation, the air in a darkroom can get a very high moisture content. Some of the chemicals used in Photography can get into this atmosphere and so there is always the risk of corrosion. Make sure the room has adequate ventilation and your stuff is properly stored when you are not using it.
darkroom rust
