Samyang 500m
Discussion in 'Photography Equipment & Products' started by carvinrocks2, Aug 10, 2010.
  1. carvinrocks2
    carvinrocks2 TPF Noob!
    Jul 12, 2010
    91
    Oklahoma
  2. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,012
    862
    Woodbridge, Ontario, Canada
  3. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    There are several similar 500mm F8 mirror lenses floating around.
    There are even a fair number of old threads around here that talk about them.
    Overall, the consensus seems to be that the quality is terrible compared to a good 'normal' lens, but for the price, then can be fun...just don't expect too much from them.
    And of course, with such a long focal length and an aperture (non variable) of F8, you pretty much need to be on a stable tripod.
  4. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    One good thing about mirror lenses is that they usually have zero chromatic aberration, which makes them perfect for taking photos of bright light sources like the moon, or birds against a bright sky.
    They are also very light weight, but that's both a positive and a negative, as the weight of a standard telephoto makes it easier to hold steady, allowing you to shoot slower shutter speeds.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    39,608
    14,809
    USA
    Mirror lenses can be fun to use,and are a good way to get a long,light telephoto very affordably. The main problem is that they are slow,aperture-wise, and 99.99 percent of them are manual focusing (Sony has anew 500 AF mirror), and the focusing is pretty critical with a 500mm lens. This means that mirror lenses are not well-suited to "action" photography. There have been some very high-quality mirror lenses made by Nikon and Vivitar and Tamron, but the majority of 500/8's are pretty cheezy.
    Here is a Vivitar Series 1 "solid cat", made by Perkin-Elmer, of NASA and space program fame...this is one of the better types of cats--the old Vivitar "solid" cats...this 600/8 uses three pounds of solid optical glass, and is part of a family of superior,professional-grade mirror teles...
    [​IMG]
  6. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
  7. usayit
    Nov 15, 2003
    9,523
    346
    Look what I ran into...
    50063 Pro-Optic 500mm f/6.3 Manual Focus, T-Mount Mirror Lens
    P09081 Samyang 500mm f/6.3 TDX Phenix Ultra Telephoto Manual Focus Mirror Lens - fits all Cameras that use Standard "T" Mounts (Required T-Mount Not Included)
    Apparently there is another 500mm mirror that's roaming around under the similar brand names. The build looks different than the one originally linked and the max aperture is f/6.3 instead of f/8.
    So I headed to pentaxforums which has a lot of users using/enjoying/experimenting with older manual focus M42 and OK lenses. There's some input there that might be interesting read:
    PentaxForums.com Third-Party Lens Review Database - Rokinon / Kenko / Bower / Samyang 500mm F/6.3 DX Lens Reviews
    For the price, it this f/6.3 "might" be ok... within limits. Also notice in one of the samples you can see doughnut shaped specular highlights.. another "characteristic" of mirror lenses which you might or might not like.
bower sly 5008 lens review
perkin elmer lens
samyang 500mm f8 test
