Sb-600 not firing
Discussion in 'Digital Discussion & Q&A' started by phil-ray, Dec 4, 2008.
  1. phil-ray
    phil-ray TPF Noob!
    Aug 30, 2006
    97
    Portadown Northen Ireland
    Hope this is in the right section, if not please move it admin.
    right so i got a sb-600 new from amazon a week ago for my Nikon D200 and from the off set it has worked brilliantly up un-till tuesday. where it just stopped working.
    its got all the settings and stuff on the back but its just not firing or making that humming noise when the flash is meant to be recharging i hope you know what i mean. also the 'ready' light on the back of the flashgun does not light up any more tho flashes a few times after i take a picture, even know the flash its self does not fire.
    well after it goes on stand by it says 'bat' which according to the manual is the battery, at the time of starting i had a set of engergiser batteries in, non rechargable 2500's so went out and buy my self a set of rechargable 2500 engergiser's wait till they have charged up and still the same problem the flash shows all the writing and the light works on the flash, even the auto zoom bit works on the flash but its just not charging up and flashing. and the same 'bat' message is coming up when it goes on standby.
    so maybe thinking its the batterys again i buy a set of duracell ultra AA's and still the same problem.
    now ive tried resetting the camera, and looking in the trouble shooting part of the manual, tried turning the standby function off through the buttons on the back of the flash, i have even tried a few settings on my D200 and reset all the settings on that, but still no joy. i have tried different lens also, to see if that makes a button of difference. i may try and see if it works on my friends D50 nikon when i see him at the weekend. but i doubt that will make a diffrence.
    so now im a bit stumpt, all i can think of is something has went in the inside to think what ever batteries i put in are low power or the actual bulb has went, but surely not after a few days of use and possably 150 pics taken.
    if any one can help me that would be so great.
  2. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Couple of questions.
    Does it fire when you press the "red" FLASH test button?
    Have you set it to off-camera operation with it on your hotshoe?
    Have you set it to on-camera operation with it off your hotshoe?
    Have you made any adjustments in the Commander mode that may have an affect?
    What mode is your flash set to?
    Could be a bad unit. I've had mine about 2 years without any problems except the one I created.
  3. phil-ray
    phil-ray TPF Noob!
    Aug 30, 2006
    97
    Hi Kundalini
    it doesnt fire when i try and press the red flash test button, both on and off the camera. (this is kind of worrying me)
    i have tryed putting it in the small stand you get with me and setting the camera to comander mode with no luck in firing the flash also i made sure that the comander settings on the camera are not used, and the option of inbuilt flash is at 'ttl' with the flash at ttl also.
    would it have mattered me trying some settings with it not on the camera. but then resetting the settings useing the reset settings function.?
    on another forum someone said clean the contact points, they dont look dirty but to be honnest i have lost my little cover for the shoe for a while now, ive rubbed it with a microfiber cloth but still no luck.
  4. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    I had a similar problem. I ended up sending it back to Nikon to get serviced.
  5. phil-ray
    phil-ray TPF Noob!
    Aug 30, 2006
    97
    and did they fix it?
    may i ask how much that did cost you?
  6. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    Oh sorry, yes they did fix it. It ended up being like $90 when it was all said and done.
  7. phil-ray
    phil-ray TPF Noob!
    Aug 30, 2006
    97
    umm cheers.
    ive found a nikon repear place in ireland, where i am so i may phone and see if they can help me in some way
    any other ideas welcome
  8. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Sorry Dude, but it sounds like you may have a bad specimen. The tell-tale was that the test fire isn't working. I'd contact your sales contact and also Nikon to report a problem.
    Don't worry too much, the SB-600 is a good flash and I'm sure this will be resolved.
  9. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    yeah I am very confident that you will get this resolved. The flash is nice. I had a broken bulb...
  10. phil-ray
    phil-ray TPF Noob!
    Aug 30, 2006
    97
    fired an email off to the place I bought it off explaining what's happened and what I've tried to reslove this. I've asked about getting a replacement or would the cover costs if I send it to a repar centre. I'll let u know how I get on
  11. roadkill
    roadkill TPF Noob!
    Jan 26, 2008
    392
    Atlanta GA
    Does Amazon have return policy?
d2x sb600 poor image
nikon sb 600 flash not firing
nikon sb-600 flash not firing
nikon sb600 ready light but doesnt fire
nikon speedlight sb600 not flashing
sb600 not firing
