SB-600 or SB-800?
Discussion in 'Beyond the Basics' started by sebarrier3, Nov 25, 2008.
  1. sebarrier3
    sebarrier3 TPF Noob!
    Jun 17, 2006
    16
    Mountains of NC
    Hello all!
    I have a Nikon D80.. I do mostly outdoor photos and thus far I have had no need for a large flash unit. I was asked to do an indoor wedding next summer and declined because I felt I didn't have the proper equipment (flash) so the client offered to buy me whatever flash I need to get the job done. How could I pass this up? I am researching the SB-600 and SB-800 but wondered if anyone had any advice from experience with either product? Or perhaps a different flash?
    Thanks in advance and I hope everyone has a great Holiday this week! :D
    ~Sarah
  2. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    yes.... the SB600 will work fine... and the SB800 will work even better... buy the SB800 if you can afford it simply for it's higher guide number for outdoor flashing...
    or SB900
    EDIT: not sure if the D80 has on board wireless commander / if not the SB800 will also fire your future flashes off camera..
  3. czsmola
    czsmola TPF Noob!
    Nov 3, 2008
    48
    Kingston
    I also have D80 and a student so my budget for camera stuff is practically nothing but my choice is between the 800 and 900
    as to the comment above you are able to fire the 800 off camera using commander mode with the built in flash
  4. K_Pugh
    K_Pugh No longer a newbie, moving up!
    Sep 26, 2005
    1,343
    75
    Scotland
    The D80 has commander mode so a SB-600 will do just fine, the only reason to go for the 800 or 900 is slightly more power, which is always handy.
    If it's one of those things that will be covered by expenses from your client and they're ok with it, just get the best you can I'd say.
    I've got a D80 and an SB-600, no problems so far. Even in i-ttl mode it works a treat. You wont go wrong with whatever one you buy.
  5. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    If you choose the SB-800... do it fast. They are officially discontinued and the SB-900 replaces them. $450 battery powered strobe anyone?
    For the cost of that one strobe, I can pickup a freaking Alien Bees B1600 amd still have almost $100US in my pocket and the AB will be at least 5 times more powerful!
    Personally, I'm just going to go for multiple SB-600s in my setup. 2 per umbrella are even stronger than a single SB-900, and I can separate them and increase versatility if needed. They are also in the $175US each bracket.
  6. kdabbagh
    kdabbagh TPF Noob!
    Dec 31, 2007
    148
    Cairo
    Jerry,
    Can the equipment you're quoting be found online?
    I've never seen a SB600 for that price...I just checked it the other day at Vistek and it was $270 before tax.
    Not trying to doubt your words, just point me in the right direction if possible. Thanks :)
  7. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    Pfft, who cares?! They're buying, go for the SB-800! Actually, in that case, get the new SB-900 ;)
  8. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    For what you need, the SB-600 will do just fine. If they're OK with you getting the SB-800 then it does offer slightly more, but you don't need it. Its just nice to have.
  9. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    I have one of each now. The SB-600 has served me very well and there is NOTHING wrong with it. The SB-800 is a bit more hard-core and a bit more powerful. It has a lot of very interesting features I haven't even begun to scratch the surface on.
    If they are willing to spend the money and you don't feel like you're taking advantage, go for the SB-800, but you won't find yourself wanting if you "settle" for the SB-600.
    EDIT: It's good to look at a comparison chart... there *are* some differences, and interestingly sometimes the SB-600 is more suitable... and just because the SB-900 is the latest and greatest, does not mean it is the absolute best for all situations. They really do all have strengths and weaknesses. (like... for example... the SB-600 cycles and is ready to flash again quite a bit quicker than it's bigger brothers)
  10. manaheim
    Sep 2, 2005
    14,394
    3,262
  11. JerryPH
    Oct 14, 2007
    6,111
    15
    Not sure where you are shopping my friend, but check out [ame="http://www.amazon.com/Nikon-SB-600-Speedlight-Digital-Cameras/dp/B0002EMY9Y/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1227880896&sr=8-1"]HERE[/ame], [ame="http://www.bhphotovideo.com/bnh/controller/home?ci=0&shs=SB-600&sb=ps&pn=1&sq=desc&InitialSearch=yes&O=jsp%2FRootPage.jsp&A=search&Q=*&bhs=t&Go.x=0&Go.y=0&Go=submit"]HERE[/ame] and [ame="http://www.adorama.com/NKSB600AFU.html?searchinfo=SB-600&item_no=5"]HERE[/ame] for SB-600 prices *all* under $175US.
    Vistek... that may explain it... are you comparing US to Canadian prices? I'd personally never purchase in Canada. 20-30% higher prices and taxes... suck. :lol:
  12. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
    correct me if i'm wrong... but isn't the only reason the sb600 has a faster recycle time is because it has less to recycle?
    if you output equal power (say 1/4) with both flashes (SB600, SB800), they will both recycle at the same rate. the only reason an sb800 would take longer to recycle if both flashes were fired at 100% power... in this case.... the sb800 needs more time fill up the capacitor but it also discharged more flash power than the sb600 was capable of.... so this would be a moot point no?
sb 600 has no port
sb 600 reseller
weaknesses of sb600
