SB 600 problems
Discussion in 'Photography Equipment & Products' started by D-50, Aug 14, 2007.
  1. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    I went to use my sb600 last night to find it will not fire. It flashed once and nowit will not flash again. I put in new batteries so that is not the problem. any ideas on what is wrong. everythinglook fine, the ready light is on and the screen on the back works perfectly, the flash still zooms as well. It will not test fire either.
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    could you have blown the bulb out?
    I'm pretty sure you can replace them yourself.
  3. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Took it to the shop yesterday, its under warrenty so they are sending it to Nikon, hopefully it will be covered, From what i hear about Nikon's turn around time though even if its covered I probably will not see it for a month or two.
