SB-600 stop equivalent
Discussion in 'Photography Beginners' Forum' started by jands, May 10, 2011.
  1. jands
    jands TPF Noob!
    Dec 21, 2008
    161
    13
    Tacoma, WA
    Using an SB-600 in manual, what increment of power is equivalent to one stop? For example if I am at 1/4 power, take a picture, then stop down my aperture by one stop, what is the next "stop" on the flash to compensate?
  2. Derrel
    Derrel Mr. Rain Cloud
    Top Poster Of Month
    Jul 23, 2009
    36,833
    13,521
    USA
    Full, 1/2; 1/4; 1/8; 1/16; 1/32--this is commonly referred to as a "five f/stop range" of variable power. Some flashes also offer 1/64 and 1/128 power settings for a seven-stop range.
  3. jands
    jands TPF Noob!
    Dec 21, 2008
    161
    13
    Tacoma, WA
    Thanks.
  4. jands
    jands TPF Noob!
    Dec 21, 2008
    161
    13
    Tacoma, WA
    Incidentally, Derrel, I'm asking because I'm playing with the 105mm AI you recommended.
  5. KmH
    Apr 9, 2009
    38,762
    5,165
    Iowa
    Except lens aperture, divide by 2, or times 2, is a stop.
    ISO 100, to ISO 400 - is 2 stops. 100 x2 = 200 x2 = 400
    Or ISO 1600, to ISO 400 - is 2 stops going the other direction 1600 / 2= 800 /2 = 400
    Shutter speed is the same 1/200, to 1/800 - is 2 stops as is 1/1600, to 1/400.
    For lens aperture the area of a circle (imperfect) is involved, rather than the aperture diameter, and we have to use the square root of 2 instead; 1.4142 to define a full stop. f/2, to f/4, is 2 stops - f/2, f/2.8, f/4.
    Conversely, going the other way f/5.6 is to stops larger than f/11 - F/11, f/8, f/5.6
    I love math!
    • Like Like x 2
  6. jands
    jands TPF Noob!
    Dec 21, 2008
    161
    13
    Tacoma, WA
    Wow, thanks KmH. I think I got it. I'm still in the middle of letting it sink in.
    I didn't even notice (until now) flash power worked the same way (x2 /2). Now it makes sense why the flash jumps from 1/2 to to full.
  7. KmH
    Apr 9, 2009
    38,762
    5,165
    Iowa
    Since the thread started based on a flash unit, don't forget the Inverse Square Law.
    If you don't change the flash power, the amount of light on a subject is a function of the square of the distance, if the distance is changed.
    If the light is moved twice as far away, only 1/4 as much light hits the subject. If you double the distance again, only 1/16th as much light hits the subject.
  8. jands
    jands TPF Noob!
    Dec 21, 2008
    161
    13
    Tacoma, WA
    Funny that you mention that, I just was re-reading about it. It didn't quite make sense until now. A lot of things have been clicking lately... no pun intended.
flash equivalent to f stop
flash power equivalent to stops
fstops for sb600
how to stop down sb600
nikon sb 600 equivalent
nikon sb 600 f stop settings
sb 600 equivalent
sb-600 flash power stops
sb600 equivalent
what's the f-stop of sb-600 at full power
