SB 600 zoom problems
Discussion in 'Photography Equipment & Products' started by D-50, Dec 4, 2007.
  1. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    I was out shooting on saturday and my Sb600 was working fine, then all of a sudden it would no longer zoom out to 14mm. I did not hit it and knock it into anything. I dont know why this has happened. It was extremely cold that day could this have anything to do with it? Anyone have any idea of what happened. The flash still works fine otherwise but I would like to be able to zoom out to 14mm if need be.
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    you need to flip down the reflector.
  3. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    I know the reflector has to be flipped down. It was zooming out to 14mm half the afternoon and all of of sudden could no longer zoom to 14mm with the reflector down, I could however zoom through all the other focal lengths with the reflector up or down.
  4. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Pull out the batteries, replace with fresh ones and do a reset. If that doesn't resolve the issue, it may require service.
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Sounds like maybe the sensor that checks if the refractor is out is not working properly.
  6. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Thats what I think as well. Considering it works at all focal lengths except 14mm I think I'll just roll with it and not spend the cash to fix it. Im getting the SB800 anyway for christmas so I will use that as my primary flash.
  7. Mr_Bester
    Mr_Bester TPF Noob!
    Jun 25, 2007
    57
    St. Louis, MO
    I don't know if it matters, but on my canon, it won't zoom all the way out if it is straight up and down, it has to be at some angle before it will zoom all the way wide.
    I assume you have tried this...
  8. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Than just zoom it out to 24mm and flip the reflector down. That's what the 14mm setting is.
  9. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    So you're saying the only difference between 24mm and 14mm on a sb600 is the reflector? The bulb does not move between these two focal lengths?
  10. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    nope, no movement.
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Interesting. The SB-800 moves the bulb when you do that.
  12. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Very interesting, no problem then.
