SB-800 flash Problem... going off on its own!!!
Discussion in 'Photography Equipment & Products' started by RMThompson, Jun 20, 2007.
  1. RMThompson
    RMThompson the TPF moderators rock my world!
    Nov 12, 2006
    1,888
    11
    Hey guys, after my last few photo sessions I've noticed some weird behaviour with my SB-800 on my D50 Nikon.
    Sometimes, at first I thought it was random, the flash will fire when I don't press the button. I thought at first it was just possibly cycling to ensure proper charge... however I notice now that its when I move the camera a certain way. The Sb-800 has always fit a little loosely in the camera, it jiggles a bit in the hotshoe, but sometimes when I jiggle it forward, it flashes!! Am I doing something wrong? Is there anyway to fix it? Is it a hotshoe problem? It's OK because I've never been not ready for a shot, yet, but I'm sure its effecting my battery life, and its not nice when it flashes my eyes or my customers...
    Any thoughts?
  2. Mike_E
    Jan 26, 2007
    5,327
    266
    It could be a loose wire in the shoe. do you use the locking switch and if so is the foot still loose on the camera? If it is loose then your upper right contact may be touching one of the others on the camera shoe.
    mike
    does the flash go of when it's not on the camera and you shake the flash?
  3. RMThompson
    Nov 12, 2006
    1,888
    11
    Yes it's still loose after I use the locking switch, but no, it doesn't do it alone without the camera.
    Someone said it might have something to do with the "Modeling Lamp" feature, that if I turn it off somehow it might go away?
  4. Mike_E
    Jan 26, 2007
    5,327
    266
    I dunno. Take a look at your hot shoe on the camera and make sure it's not bent out. This would allow the flash to be loose.
    Looking at my 600, it's not loose although not as snug as my 28 when screwed down.
    Just for the halibut, try shooting in auto mode and manual mode to see if it's a self starter then.
    BTW does it rattle at all?
    mike
    BTW, there is some buzz that it may be an esd thing, are you geting much lifghtening there?
  5. RMThompson
    Nov 12, 2006
    1,888
    11
    ESD? what?
    Ive shot in AUTO and I mostly shoot in APERATURE mode. It does it whenever I move the camera from back to front, or put it down on a table. SOmetimes it's more than once, three times in a row if I am walking with the camera.
  6. Mike_E
    Jan 26, 2007
    5,327
    266
    I'm sorry RM, ESD means Electro Static Discharge and is a bane to electronics. If there is a lot of static electricity in the air and the flash is not making good contact anyway then an arc across the terminal from a static shock would cause the flash to go off.
    Does if do a full dump or does it recharge like it was a partial charge flash?
    Also, I was talking about shooting with the flash in Auto mode and Manual, you set this on the flash with the mode button. You may need to set your D50 to manual flash or something -I've not shot a D50.
    mike
  7. RMThompson
    Nov 12, 2006
    1,888
    11
    It's not a full dump, I am sure of it... and I can fire immediatly before and after it.
    Ive tried changing the settings with the flash as well, to no avail, but to be honest I dont know much more than AUTO and how to step it down and up...
  8. Mike_E
    Jan 26, 2007
    5,327
    266
  9. RMThompson
    Nov 12, 2006
    1,888
    11
    Called them. They just said send it in... which sucks.
    I doubt I could afford repairing something like this! LOL
  10. RMThompson
    Nov 12, 2006
    1,888
    11
    anyone else got any suggestions?
  11. Mike_E
    Jan 26, 2007
    5,327
    266
    OK, put the flash on your camera and then turn both of them on. Next remove the batteries from both with out turning them off. Take the flash off the camera and reinsert all batteries. See what happens.
    If you are still having problems borrow someone else's flash or let someone else use your flash and see if the problem still exists. If it does then you may have a problem with your top circuit board on your camera like this guy...
    http://www.nikonians.org/dcforum/DCForumID7/17006.html#0
    good luck with it!
    mike
  12. RMThompson
    Nov 12, 2006
    1,888
    11
    Ouch
    no dice.
nikon flash fires onits own
nikon sb600 fires on its own
nikon sb800 firing by itself
nikon sb800 loose
nikon sb800 randomly firing
sb800 flash will not stop flashing
speedlight sb-800 fired spontaneously
why does sb-800 flash randomly
why is my nikon sb800 flash flashing before the photo
why is sb-800 firing on its own
