SB600 and D90 help!!
Discussion in 'Beyond the Basics' started by rabhobbes, Oct 28, 2009.
  1. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    OK, I'm feelilng really idiotic right now.
    My sb600 does not seem to be talking to my D90, or vice-versa.
    I've been online, read my manuals, and nothing is working like it should. I probably missed one little (or big) thing that is messing things up.
    Whatever mode I use (Aperture, Shutter,) and change the settings on purpose, the flash is supposed to compensate for the correct exposure...right? It is not happening. I may as well be shooting all manual and setting the flash to manual, too.
    Can someone please go step by step through the settings I need to have on my camera and the flash to make it work correctly?
    Really, I'm pretty smart but this is frustrating me to no end.
    My main shooting will be at sunset on the beach with people, and indoors in large open rooms.
    Thanks!
  2. jnm
    jnm TPF Noob!
    Sep 9, 2009
    297
    Palo Alto, CA
    is your flash set to i-TTL or i-TTL BL or is it on manual?
  3. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Anything short of Auto mode it's all on you to decide the exposure.
  4. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    It shows as TTL or TTL BL. No iTTL to be found. Which I kept thinking was weird. They are not the same, right?
  5. jnm
    jnm TPF Noob!
    Sep 9, 2009
    297
    Palo Alto, CA
    sorry, i didnt mean to say 'i', the SB600 screen will just say TTL or TTL BL.
    what's your metering set at? it should be matrix for this.
  6. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    I believe it is.
    I SHOULD be able to use it the way I described, right? RE: OP's reply above. Otherwise it's all manual...
  7. jnm
    jnm TPF Noob!
    Sep 9, 2009
    297
    Palo Alto, CA
    yes, you should be able to change things like aperture and shutter speed and have the flash compensate as best it can when in TTL or TTL BL. if the flash is set properly and the camera is on matrix metering the only other thing i can think of is your exposure or flash compensation is set wrong. that or just try restoring the camera to all factory defaults and go from there.
  8. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    I thought so...thanks for your help. I will go back and check everything.
    Just wanted to make sure I wasn't missing anything goofy or obvious!
  9. jnm
    jnm TPF Noob!
    Sep 9, 2009
    297
    Palo Alto, CA
    it should be pretty straight forward, youre not going crazy.
