SB900 set up with D200
Discussion in 'Photography Beginners' Forum' started by spinxy, Sep 28, 2008.
  1. spinxy
    spinxy TPF Noob!
    Feb 10, 2008
    19
    Essex England
    how do i calibrate the sb900 to work with the d200 wirelessly!!
    i did have the flash triggering, but the timing seemed to be out, now i've managed to sod it up so the flash don't go off at all!!
    also does anyone know a good tripod/unbrella stand which i can use with the sb900
    Thanks
  2. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    make sure the built in flash in the D200 is set to Commander (it'll be an option in the flash settings menu), and make sure you DON'T have the SB900 set to SU-4. The misfiring is probably because of that.. SU-4 mode is an optical slave that's triggered by any flash output, and the way CLS fires flashes is with a monitor, or pre-flash. The pre-flash sets off the optical slave, causing the SB900 to fire early. Could be something else.. but try that..
  3. spinxy
    spinxy TPF Noob!
    Feb 10, 2008
    19
    Essex England
    i checked the settings it's not set to SU-4
    also i am having trouble trying to set the d200 to commander i have been looking through the flash/bracket menu but nothings jumping out at me, i also can't seem to find any channel settings on the camera, i have set the flash to gr A and channel 1
  4. spinxy
    spinxy TPF Noob!
    Feb 10, 2008
    19
    Essex England
    also i am having trouble trying to set the d200 to commander i have been looking through the flash/bracket menu but nothings jumping out at me, i also can't seem to find any channel settings on the camera, i have set the flash to gr A and channel 1 but can't seem to replicate these settings on the camera
d200 and sb-900
d200 and sb900
d200 sb900
nikon d200 manual flash settings
sb-900 and d200
sb-900 on a d200
sb900 d200
sb900 d200
sb900 with d200
syncing my d200 with sb-900
