Scanner Question
Discussion in 'Photography Equipment & Products' started by Bluesfan, Sep 15, 2007.
  1. Bluesfan
    Bluesfan TPF Noob!
    Sep 15, 2007
    St.Louis Mo
    Hello all I am new to the forum but not to photography. I need your opinions on scanners. I have a ton of negatives(35mm) to scan. I am on a tight supply of cash also. So in your opinion what is the best bang for the buck scanner available? If anyone has a idea on what would work the best that would be fantastic. Thanks :)
  2. Cero21
    Cero21 TPF Noob!
    May 6, 2007
    125
    Canada
  3. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
    Welcome to the forum.
    The best bang for the buck would probably be a flatbed of some type. You will need to look for one that has a film scanning tray or attachment.
    For better quality, you should look into a dedicated film scanner (not a flat bed)...these are more expensive though.
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    You need to decide a budget. Buying a scanner is much like purchasing a DSLR. Budget.. first.. then go from there.
    Dedicated have always been the route to the best quality scans of film. They are expensive. Those capable of medium format are even more expensive.
    I'm a big Epson fan... printers, scanners, image tank, and R-d1. I have found that the only flatbed scanner that can compete with the likes of a dedicated is the V700 (same unit as the V750). They are bargain in comparison to dedicated scanners but expensive when compared to other flatbeds. I continue to be amazed by the quality of the scans and my only complaint is the darn flimsy negative holders.
    Previous to the V700, I had the 3170. Also a mid-low-end scanner that you can find used REAL cheap. Performs well, although it is obsolete by todays standard.
    So basically in the Epson line, you have some good choices based on how much you want to spend.
    4490 - $180
    4990 - $400
    V700 - $550
    Here was my initial impressions of the V700 when I first purchased it:
    http://thephotoforum.com/forum/showthread.php?t=62119
  5. usayit
    Nov 15, 2003
    9,523
    346
    Oh btw..
    The refurb unit that Cero pointed too... it is a good buy. I've purchased a couple refurb units direct from Epson, including my R-D1, and they have all been good buys. THere are some wonderful discounts to be found on Epson Refurb direct... the R-D1 I purchased was about 58% off the originl price.
