School yearbook photos
Discussion in 'Digital Discussion & Q&A' started by celeste, Aug 27, 2009.
  1. celeste
    celeste TPF Noob!
    Aug 27, 2009
    Louisiana
    I will be taking school yearbook pictures this year. The ages range from k- 12th grade. So lots of height variation. What is the best way to make all the shots look uniform, in other words, same amount of backdrop at the top. Should I crop after or what. I need advise from someone who has done this before....
  2. ScottsdaleImages
    ScottsdaleImages TPF Noob!
    Aug 28, 2009
    33
    Scottsdale, AZ
    Celeste,
    Back in the day when I did that, with 70mm Nord film cameras, the focusing screen had a circle that we put the head into to keep head height uniform. I assume thats not an option with your equipment, so post cropping is probably your best answer.
    Russell
    Scottsdale Images
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,036
    15,017
    USA
    Photograph the children seated on a solid posing stool, with their feet placed on wooden boxes at an angle to the lens-to-subject axis; do not have their shoulders perfectly squared up to the camera--have the kids aligned so thier bodies are angled to the camera at least a little bit, and so their shoulders go across the entire bottom of the frame. The boxes for foot positioning are called "apple boxes", and they help keep your subjects' feet positioned where you want them to be, which keeps them from squirming around on the posing stool.
    Keep the camera elevated a little bit above nostril height....raise or lower the camera so that you are not looking up into the nostrils. When seated, people are less likely to exhibit the tremendous height variation they do when standing.
    Shoot all the primary grade kids in K-4 from 8 feet; Shoot grades 5-8 at 9 feet. Shoot high school (grades 9-12) and adults from 10 feet away. All using the same focal length lens. For precise head placement, it depends on your camera's viewfinder AF focusing patches; try and figure out which focus patch needs to be placed "where", depending on your brand and model of camera. The bottom of the frame is the "base" of the portrait,so please try not to leave that awful dead space at the bottom left or bottom right of the frame--the bottom of the picture needs to be filled with clothing all the way across on a yearbook photo. With a Canon 20D-50D, the two AF brackets can be positioned at the eye-level (roughly) of your subjects. Pick a bracket and position it consistently somewhere--on the airline, on the eye level, whatever.
    Try and get the backdrop well out of focus by making sure it is well behind your sitters,and by using a reasonably long focal length lens.
  4. celeste
    celeste TPF Noob!
    Aug 27, 2009
    Louisiana
    Thanks you so mcuh that is a huge help. I may have a few more questions when i think this all out, thanks again!
