scratch disk problem!!!
Discussion in 'Graphics Programs and Photo Gallery' started by spako, Mar 27, 2006.
  1. spako
    spako TPF Noob!
    Jan 24, 2006
    1,097
    10
    Luxemburg
    I need Help!
    I tried to open a new file in PSC2 but the error message "scratch disk is full" appears.
    Could anyone tell me what I can do to be able to open new files again?
    Thank you!
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Did you try a restart?
  3. spako
    spako TPF Noob!
    Jan 24, 2006
    1,097
    10
    Luxemburg
    several times!
    I'm even defragmenting my harddisk to get some additional space but I don't know if that will do any good... I'm lost here!
  4. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    close all windows your not using.... if you can reduce the document size... i.e flatten layers, discard unwanted effects, then do so. This is all off the top of my head, but you can also adjust scratch disks in the ps prefernces... basically whats happening is theres too much open, memorywise, than it can handle.
  5. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    additional:... free up disk space.... the one scratch disks is allocated to... which is probably your main one.
  6. spako
    spako TPF Noob!
    Jan 24, 2006
    1,097
    10
    Luxemburg
    Thank you!
    I will try to do this!
    maybe I have to many programms running at a time!
  7. TRoskell
    TRoskell TPF Noob!
    Apr 5, 2006
    6
    If you have another hard disk you could also assign that as a secondary hard disk.
  8. 2framesbelowzero
    2framesbelowzero TPF Noob!
    Mar 24, 2006
    300
    im not using PS but in Gimp, you go into settings/preferences and increase the allocation of space specified for the applications 'scratch disk'...i.e you may not have run out of physical-space - just exceeded the presently stated buffer-size.
