SD Card Speed
Discussion in 'Photography Beginners' Forum' started by JasonLambert, May 25, 2010.
  1. JasonLambert
    JasonLambert TPF Noob!
    Apr 16, 2010
    737
    14
    Hermitage, PA
    I have been shooting with my class 4 card for a while now and never had a problem with it bogging me down if I needed to burst 3 or 4 shots (RAW). In fact I know when I first got the card it was able to take 6-10 shot bursts (RAW) without a problem.
    The other day I was out taking some shots of my daughter and she was running so I held the shutter release down and got "click click............... click............... click" The first two were quick but the last two were about 3 seconds apart.
    Now from what I have read, a class 4 has a minimum write speed of 4 MB/Sec but most do faster than their rating. I know I should be using a class 6 or greater in my XSI but just haven't gotten around to it. My question is, do SD cards slow down over time? Also, do you recommend one brand over another and why?
    Thanks,
    Jas[​IMG]n
  2. cfphoto
    cfphoto TPF Noob!
    May 11, 2010
    58
    Richmond, VA
    Maybe try formatting it? I'm not an expert, but I believe I read somewhere, where "deleted" artifacts left on your card can slow it down considerable over time. Might be worth looking into to salvage some of those old cards.
  3. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Jason
    Were the batteries fresh?
    as mentioned above, have you recently formatted your card in the camera?
    How full was the card?
    What speed is your camera capable of?
  4. JasonLambert
    Apr 16, 2010
    737
    14
    Hermitage, PA
    Yes, The batteries were fresh and I format the card in the camera after dumping the previous images onto the computer every time. This happens even when everything is fresh and I have just started shooting. My XSI should do a 3.5 frames per second burst shooting for up to 53 JPEG or six RAW frames. I can't even get close.
  5. cfphoto
    cfphoto TPF Noob!
    May 11, 2010
    58
    Richmond, VA
    Ha, never thought of plain old batteries possibly being the issue, good catch.
  6. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    I dont recall that happening with my XSI, and I was shooting Class 4 Lexar cards. Odd... I think people have covered the basics of what to look for, batteries, formatting,...
    I know when you do some in camera noise reduction for long exposures, it doubles the lenght of time that the picture takes to record to your card, but thats not your case. Are there other settings you did that require more camera processing?
    In terms of which cards to buy, I've always had Lexar for my SD and Sandisk for my CF. Never had an issue with either
  7. Danksalot
    Danksalot TPF Noob!
    May 22, 2010
    18
    Dallas TX
    Were you using the flash? Your camera will wait for it to "charge" even it it's the camera's ready to take the next picture.
  8. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    83
    Riverview, New Brunswick, Canada.
    Just a thought... Maybe your card is worn out... How many times have you formatted it?
    One issue that flash memory has is that its usually only good for a certain amount of read/write cycles.
  9. KmH
    Apr 9, 2009
    40,526
    5,539
    Iowa
    Memory wear isn't an issue until you approach 100,000 write/erase cycles.
    www.wikipedia.org/Flash_memory
    Was the ISO on Auto, and was high ISO noise reduction turned on?
  10. dhilberg
    dhilberg TPF Noob!
    Jul 26, 2008
    516
    Washougal, WA
    Did you have the camera in continuous-focus mode and were you tracking the subject? Some bodies have a continuous-focus mode with a focus priority. The shutter won't release unless the subject is in focus, even if you're holding the shutter release button down. This will slow down your fps significantly while your camera tries to maintain focus. This is opposed to continuous-focus mode with shutter priority, where the shutter will be released whether the subject is in focus or not.
    Usually the continuous+focus mode is available only on the higher-end bodies, so I'm not sure if it will apply to your XSI, but it's a thought. My D90 has it but it's only available in AF-A mode. You can't actually select it and apply it to AF-C mode like with the D300/D300s and above.
  11. DerekSalem
    DerekSalem TPF Noob!
    Aug 8, 2009
    660
    10
    Cleveland, OH
    As some people have noticed make sure to not using AI Servo and also make sure Highlight Tone Priority and noise reduction are turned off. All 3 of those things will slow down the burst *significantly*
  12. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    I was going to mention if you had fiddled with some camera settings. The other posts covered that.
