SD vs CF
Discussion in 'Photography Beginners' Forum' started by eddiesimages, Aug 26, 2006.
  1. eddiesimages
    eddiesimages TPF Noob!
    Aug 5, 2006
    138
    NC
    What is the difference between the SD cards used in the Nikon D50 and new D80 compared to the CF cards used in the older model D100 and D70s? Is one card better than the other? Thanks for any response.
  2. JDP
    JDP TPF Noob!
    Aug 16, 2006
    285
    Minneapolis, MN
    Well, the biggest things are that SD cards require less electronics, less power, less space then CF, and you don't have to worry about bending pins. SD also has a protection tab to keep you from accidentally deleting pictures on it. Neither is really 'better', but SD is newer then CF. It seems like Nikon might be moving to SD, one of the reasons I'm waiting to see what the D300 has to offer (Or whatever the D200 upgrade is).
  3. bigfatbadger
    bigfatbadger TPF Noob!
    Mar 19, 2006
    464
    Nottingham, UK
    The CFs are bigger, in terms of performance, they're both pretty much the same. You'd not notice a difference between them.
  4. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    I like CF cards because they're bigger and harder to lose ;-)
  5. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    When Digital Photography was first catching on, SD didn't exist in its current form - only the earlier, more immature MMC format. At the time, CF had a clear advantage in terms of speed and capacity, so it became the standard for pro photography. Within a couple of years, SD had equaled CF in performance and its capacity has grown further and further - 4GB hunks are commonly available now. It's cheaper, lighter, smaller (which is a huge bonus in camera real estate), draws less power, and is superior in essentially every way. CF has held on in Pro Cameras out of sheer tradition, but that's slowly changing.
  6. bigfatbadger
    Mar 19, 2006
    464
    Nottingham, UK
    Which doesn't sound important until you misplace a 1gig Ultra II SD card, like i've just done.:x
  7. Ouch!
    Tiberius is right though - SD are better, but like a lot of other people I'm stuck with CF for my Canon bodies. Buy whatever camera you like, and let that be the determining factor in the memory you use.
sd vs cf cards?
