SD vs SDHC for XSi
Discussion in 'Photography Equipment & Products' started by zbo2408, Dec 11, 2008.
  1. zbo2408
    zbo2408 TPF Noob!
    May 8, 2008
    170
    Charleston, SC
    Hey all, I am getting an XSi for xmas w/ 18-55 & 55-250 from BH...
    I have searched the internet for the differences between SD & SDHC (these are the media accepted by the XSi) and I still don't feel like I have a good understanding... Could someone either link me to a really good article / thread or explain the differences, the safety of each, the speed of each... Also if one or the other works better with the XSi for what ever reason...
    Thanks!
    ps (hope this isn't an annoying repeat topic)
  2. lids369
    lids369 TPF Noob!
    Nov 4, 2008
    88
    Southern NH
    sdhc is faster than sd. thats the biggest difference.
  3. Pure
    Pure TPF Noob!
    Oct 22, 2008
    420
    Get a Sandisk Extreme III SDHC 2/4/8 GB Card.
    There's two versions, the 30mb/s edition, and the regular 20mb/s edition. Get which ever you feel you need.
  4. zbo2408
    zbo2408 TPF Noob!
    May 8, 2008
    170
    Charleston, SC
    Can someone give me an idea of how many raw images of the highest res I can fit on there?
    It looks like a raw file is approx 15mb according to Canon. So that would work out to about 66 per gigabyte? Am I thinking that through correctly?
  5. zbo2408
    zbo2408 TPF Noob!
    May 8, 2008
    170
    Charleston, SC
  6. javig999
    javig999 TPF Noob!
    Oct 2, 2007
    67
    I use a 4 GB class 6 Extreme 3 and get about 215 - 240 images on it depending on the settings (ISO in particular) shooting RAW.
    Best of luck...
  7. Ecas32
    Ecas32 TPF Noob!
    Nov 21, 2008
    323
    Florida
    i also use a 4gb kingsman (i think thats what they are called....) and i can fit about 230-250 RAW files on it. jpeg you can fit about 700
  8. lids369
    lids369 TPF Noob!
    Nov 4, 2008
    88
    Southern NH
    i suggest having two.
  9. viridari
    viridari TPF Noob!
    Dec 4, 2008
    86
    Raleigh
    SDHC is High Capacity. Old SD-compatible devices couldn't address more than (IIRC) about 4GB of space. SDHC compliant devices can address much more. So you can slap a 16GB or 32GB SDHC card in there and be ready to rock.
  10. Drake
    Drake TPF Noob!
    Nov 19, 2007
    684
    10
    Generally speaking, when an SD card has up to 2gb capacity, it's called SD, if it has 4gb or more, then it's SDHC. Well, there's a bit more than that, but that's all you need to know. Neither of them is faster, they both come in various speed versions.
  11. g0bl0k
    g0bl0k TPF Noob!
    Jul 8, 2008
    26
    Texas
    i would suggest get 2 or more lower capacity SD instead of 1 high capacity. if you only have 1 with high capacity (4gb and up) and in case something happen, you will lose all your images worth of 4gb (or even more). if you have multiple SD, at least you only lose 2gb. you get the point. just a tip. ;)
  12. Drake
    Drake TPF Noob!
    Nov 19, 2007
    684
    10
    That's what I'd do. Or at least the Sandisk Ultra II with whatever capacity you feel like you need. I've got a 2GB Ultra II CF (10mb/s) in my XTi and a 2GB Ultra II SD (15mb/s) in my pocket cam, and couldn't be happier. Don't buy cheap cards from companies you've never even heard of, it might save you a copuple problems (or photos to be precise).
