Sears KS500 lenses
Discussion in 'Photography Equipment & Products' started by skyonfire, Aug 1, 2006.
  1. skyonfire
    skyonfire TPF Noob!
    Jul 4, 2006
    522
    Northern Kentucky
    Hi all.. Does anybody know what lens are compatible with the Sears KS500? I'm looking for a macro lens and a wide angle lens. Thanks in advance!
  2. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    It probably uses the Pentax K mount. You might see if you can put a Pentax lens on it to make sure. If so any lens with a K-mount will work. Besides Pentax, many other lens manufacturers build lenses with a K-mount.
  3. skyonfire
    skyonfire TPF Noob!
    Jul 4, 2006
    522
    Northern Kentucky
    Actually I did some more research and was able to find out that it takes screw mount lenses.. Does that mean it can take any brand of screw mount lens? Sorry to ask so many questions. Thanks in advance!
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    From what I've found, it is a K mount.
  5. skyonfire
    skyonfire TPF Noob!
    Jul 4, 2006
    522
    Northern Kentucky
    OK... so how do I know which it is?
  6. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Hmmm... I've found sources claiming both screw mount and K-mount.
    Take the lens off. If it screws around and around, and has threads on it, it's a screw mount. I'd assume M42 screwmount, which is what Pentax Spotmatics used. You probably won't need to push a button to get the lens off if it's screw mount.
    If the lens comes off before it rotates all the way around, and has metal flanges (bayonet), instead of threads, it's a K-mount. You probably will need to push a lens release button if it's bayonet mount.
  7. skyonfire
    skyonfire TPF Noob!
    Jul 4, 2006
    522
    Northern Kentucky
    Hey.. I just called the local pro photo shop and them told me that it is the K mount so... Problem solved.. Thanx for the help though!:thumbup:
sears ks 500
sears ks 500 camera
sears ks500
sears ks500 flash
