second portrait session...something is missing?
Discussion in 'The Professional Gallery' started by shingfan, Mar 14, 2007.
  1. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    i dont know how to say it.....but they just dont give me the studio feel.....i guess with a stuido high power strobe + softbox + a proper backdrop....it makes a world of difference... (I was shooting those with SB600 off the camera with background being my living room wall) .......can anyone please give me some techincal opinion as to what i need to do to achieve more studio feel or better result......is it a matter of equipment that i'm lacking (proper backdrop and strobes).....or is it a terrible lack of skill that mess up the exposures? Any post processing that could have done to make them look better? Any comment is appreciated. Thank You!!!
    #1
    [​IMG]
    #2
    [​IMG]
    #3
    [​IMG]
    #4
    [​IMG]
    #5
    [​IMG]
    #6
    [​IMG]
  2. Big Mike
    Dec 16, 2003
    33,830
    1,812
    Edmonton
    I think the lighting is pretty good; it's soft and from the side. They do seem to be lacking contrast and maybe sharpness.
    The yellowish) wall doesn't really help...but I like gradient that you have in the last two.
  3. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    yes....they seem to be lacking contrast.....and sharpness i think is from focusing issue.......because some of them do have sharp focus (the ones that i dont like...how ironic).....lol :p
    the yellowish wall is my only resource in my house (either yellow or blue walls in my house....no white walls other than the kitchen and closet).....otherwise i'll need to use a blue wall with more narrow space......but then in order to use this wall i'll need to take away my bookshelf....my sofa.....my paintings....my coffee table...pretty much all the furniture within the area.....so conclusion is "the yellow wall is better"......lol :p.......thanks a lot for the reply and it is great to hear more opinion and improve my skills
  4. Big Mike
    Dec 16, 2003
    33,830
    1,812
    Edmonton
    Here is a quick edit. Levels, curves and Unsharp Mask.
    [​IMG]
  5. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    mind to show me the adjustment values? i'm still new to photoshop.....not sure most of the time what range of values i should use when adjusting my photos
  6. Digital Matt
    Jan 30, 2004
    5,346
    65
    Santa Barbara, CA
    If you only have one light, you should buy a reflector, or a large piece of white foamcore, so you can bounce some light and create different ratios.
  7. Big Mike
    Dec 16, 2003
    33,830
    1,812
    Edmonton
    I just did a quick edit, flattened it and saved it...but I'll give you the basic idea.
    I created a levels adjustment layer and grabbed the left slider and moved it toward the middle...just a little, maybe 5% to 10%. Then I did the same with the right side slider. This helps to make the highlights white and the shadows black.
    Then I created a curves adjustment layer and made a slight S-curve. I grabbed a spot 1/4 from the bottom and moved it down just a touch, then grabbed a spot 1/4 from the top and moved it up just a touch. This gives contrast to the mid tones.
    Then I applied USM to the image...80, 1.2, 0 (give or take). These numbers will change for a full sized file.
  8. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    so the difference in light ratio would yeild a more contrasty image....is that correct?
    so even lighting that lits the entire subject is not as good as more contrasting light source creating more depth of "feel".....do i get the idea right?
  9. Digital Matt
    Jan 30, 2004
    5,346
    65
    Santa Barbara, CA
    A broader light ratio will yield more contrast, yes.
    There's no such thing as "not as good" when it comes to lighting. It all depends on what you want to do. You'll at least have more options if you add something to bounce light.
  10. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,123
    7,463
    Mid-Atlantic US
    My opinions are coming from a vast well of ignorance about lighting and I am only reponding to the pictures as I see them so take them with a lot of skepticism.
    IMO, the last 3 are really good and can be made even better with a little more contrast enhancement
    #1 is a not-good angle for her because it makes her face look fat. her hand is OOF.
    #2 - I', not sure but maybe the camera is too low.
    #3 is the one that IMO shows a real problem.
    There's a lot of side light so it makes her skin look rough and the level of light is dramatically different between from her face and her neck. This can be improved with a lot of PSing but there is a basic lighting problem.
  11. The_Traveler
    Dec 11, 2006
    18,123
    7,463
    Mid-Atlantic US
    maybe a little too much PS, but you get the idea.
    [​IMG]
  12. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    Traveler....what did you do to get this effect?....
