Self Portrait - Opinions if you please
Discussion in 'Photography Beginners' Forum' started by crashcart, Jun 3, 2009.
  1. crashcart
    crashcart TPF Noob!
    Jul 11, 2008
    74
    4
    Philadelphia, PA
    Took this in natural light, 50mm f1.8. I know that my head is tilted a little, but does that really detract? If you have any other thoughts, please let me know. Thanks in advance. And yes, the cropped version is my avatar, but may no longer be depending on what you tell me. ;)
    [​IMG]
  2. Sherman Banks
    Sherman Banks TPF Noob!
    Feb 24, 2009
    871
    Rain City
    I would personally push the levels a bit more, but it's not bad. The asymmetry is a bit odd though.
  3. crashcart
    crashcart TPF Noob!
    Jul 11, 2008
    74
    4
    Philadelphia, PA
    Not to sound dumb, but specifically, what levels are you talking about?
  4. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    It looks like you just held the cam in front of your face and snapped the shot. Why not include the entire face and put some thought into how you want it to look (subject, background, lighting, etc.).
  5. Sherman Banks
    Feb 24, 2009
    871
    Rain City
    Basically pushing the contrast. By pushing the levels, I'm saying to push your darker values towards black, your lighter values towards white, and adjusting your middle values to balance out the exposure. If you're using Photoshop, add a Levels adjustment layer and move your sliders inward and adjust the central slider to your liking. If you're not using Photoshop (or any editing program), your camera most likely has in-camera editing where you can just add more contrast.
  6. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Snapshot.
    That's all I can think of to describe me thoughts on it.
  7. crashcart
    crashcart TPF Noob!
    Jul 11, 2008
    74
    4
    Philadelphia, PA
    Thanks for the tips, everyone. I will keep myself planted firmly in the Beginner's Forum and change my avatar ASAP :sillysmi:
  8. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,971
    Cleveland, Ohio
    Sherman, you just taught me something valuable!
    I didn't know you could create adjustment "layers"!
    I always applied directly to the image.
    Thanks!
  9. Sherman Banks
    Feb 24, 2009
    871
    Rain City
    I always duplicate layer before applying any effects directly to the image, but the adjustment layers are great because you can adjust the opacity/blending options, etc.
    Crashcart, don't change your avatar man. The shot is not bad, just needed some minor changes to make it stronger. Here is a quick edit I did in Photoshop, and I can fully explain the adjustments made if you like it. Of course, this is pretty gritty (which I kind of define my style as), but I assume you weren't going for a glamour shot anyways right?
    [​IMG]
  10. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    Lol. I had a snarky comment but you nailed it. And I would never use the "Levels" command to adjust contrast in my image, unless some obvious edits (underexposure for example, or not deep enough blacks) are needed.
    For contrast edits I would first convert my image to the LAB-mode, and then add a Curve Adjustment Layer. In the Luminosity layer (which will be the first layer) add a simple S-curve (drag the line down on the left side, and drag it up on the left side) and bam - Instant-Contrast. You can also adjust for any underexposure in the luminosity panel. The reason this is BETTER than using a Levels adjustment in the RGB color space, is that in LAB, the luminosity ONLY affects the "brightness" values of the image - it will NOT touch the actual colors. RGB adjusts the color values in any layer mask you apply.
  11. Sherman Banks
    Feb 24, 2009
    871
    Rain City
    Ahhh... Good to know. :thumbup: I'll have to mess around with that this evening. We're all learning something new here!
  12. crashcart
    crashcart TPF Noob!
    Jul 11, 2008
    74
    4
    Philadelphia, PA
    Sherman, awesome job!!
    Did a retouch in Photoshop. Thoughts on this?
    [​IMG]
