Sensor cleaning? Got a couple dirt specks
Discussion in 'Photography Beginners' Forum' started by maulrat, Jul 20, 2009.
  1. maulrat
    maulrat TPF Noob!
    Jul 23, 2008
    652
    San Diego, CA
    Should I have my sensor cleaned? I've noticed some dust on my photos in the skies for a couple months now. Today, I just noticed 3 specks of dirt when looking through my view finder; solid black dots. I removed my lens and lightly blew air into the body using a baby nose mucus sucker thingy but nothing too rough. I didn't lockup my mirror of had the sensor exposed or anything. This did not help. I can still see these specks. I know they are not on my lens because when I change lenses, the speck are still viewable through my viewfinder. I just purchased a sensor cleaning kit. I know and will be super extremely careful when cleaning my sensor. I just wish I knew, if these specks are really on my sensor or somewhere else. I've cleaning my view finder thuroughly on the outside. When the camera is off, I can still see these dust specks through my view finder. Thanks for all help and suggestions.
  2. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
  3. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Ever thought about cleaning the sensor yourself? I clean my own sensors (Canon XTi, 40D and 5D) using the Copper Hill Method.
    If you see the specs in your viewfinder, the dust/dirt is on the focusing screen or the mirror (most likely the focusing screen)...you won't see dust that is on your lens or the sensor through the viewfinder.
    You might want to get a large Rocket Blower since it blows filtered air through the nozzle. Don't use the snot sucker anymore.
    Take a close look at the focusing screen and the mirror. Don't touch the mirror whatever you do. If everything looks clean you may have dust/dirt on the inside of the focusing screen.
    You'll get the sensor dust with the sensor cleaning kit, but dust in the viewfinder is somewhere else. Remove your lens hold the camera upside down and check the focusing screen (the white translucent looking thing that the mirror is pointing at.
  4. maulrat
    maulrat TPF Noob!
    Jul 23, 2008
    652
    San Diego, CA
  5. maulrat
    maulrat TPF Noob!
    Jul 23, 2008
    652
    San Diego, CA
    Thanks Samanax. I'll have to check this out when I get home. It probably isn't the mirrior because I remember checking it last night. It's probably on the focusing screen. If blowing air doesn't remove the spec, is the sensor cleaning kit safe for cleaning the mirror and the focusing screen? I purchased this earlier.
    Sensor Cleaining Kit, Type 2
    I sure hope it gets here before my shoot this weekend.
  6. PhotoXopher
    May 27, 2009
    3,475
    Why? That's what it's made for... works great.
    If you read the info at the link I posted you'll notice it's not the lens cleaning kit, this one is for the sensor.
  7. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Not sure if I would use it on the focusing screen. I think the screen is made of plastic and alcohol can damage plastic. E2 uses 3 different kinds of alcohol. I wouldn't even try to wipe the focusing screen to keep from scratching the surface. I would just use a Giottos Rocket Blower or just learn to live with the spots.
  8. maulrat
    maulrat TPF Noob!
    Jul 23, 2008
    652
    San Diego, CA
    That's my plan as of now. I've done a little research on the net. It seem this screen can be changed if you mess it up but I don't need another headache. If the rocket blower won't get it out, then I'll probably just leave it since I don't see the specks in my photos. The less messing around inside my camera body, the better off I'm gonna be.(imo)
camera sensor cleaning oahu
camera sensor cleaning san diego
dirt on camera sensor
how to clean a speck from sensor
photos with specks
picures with sensor.speck
specks latest photos
specks on photos
where to get my image sensor cleaned on oahu
why is my camera translucent screen dirty
