Sensor Cleaning Mishap: Help
Discussion in 'Beyond the Basics' started by CanonSnob, May 6, 2008.
  1. CanonSnob
    CanonSnob TPF Noob!
    May 25, 2007
    106
    Denver
    I had a race to shoot the next day so I went out got some sensor swabs to clean some dust that had been bothering me on my sensor. Followed the directions of one drop of the fluid and full swipes across the sensor. Did some test shots and all looked good, all dust was gone. Well I shot all the next day and it wasn't until I got home and uploaded the photos that I noticed that any motion shots, or anything with sky showed streaks across the whole sensor... top to bottom, left to right. :banghead:
    They aren't terrible, and it only makes up about a 1/4 of the work shot were they are visible. Anyhow, was wondering what others technique on getting them edited out would be. On the motion shots I can select and mask out the driver and then extend the motion blur in filter. But in the ones with sky in the shot, I cant really do motion blur in the sky... the clone stamp is useless cuz it just clones other streaks, and the healing brushes aren't helping all that much either due to the fact that it is streaked with very little clean room in between streaks.
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    without seeing the photo it's hardly fitting to recommend a solution. I still don't see how the healing brush wouldn't be effective yet.
  3. Dubious Drewski
    Dubious Drewski TPF Noob!
    Jan 18, 2008
    909
    4
    Lethbridge, Alberta, Canada
    I would never use any liquid on the sensor anyway, for this very reason. Although ironically, your best solution for cleaning the sensor now would be a lens-cleaning solution. I can't imagine what else would work better.
    When I've got dust (And the self-cleaning mechanism can't shake it off) I employ a dry Qtip and fantastically delicate touch. So far so good.
    (Yes, I know about the possibilities of lint - but it's a non issue)
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    What camera are you using? I don't think you can use Eclipse on the newer ones, you have to use Eclipse E2. I'm not sure exactly which cameras are affected by this, but I know the XT isn't one of them. Not sure about the XTi or XSi.
  5. CanonSnob
    CanonSnob TPF Noob!
    May 25, 2007
    106
    Denver
    I use a Canon 1D MKII
    The healing has to sample a good area to replace a bad area... that would require a good area to sample from. I went back&forth across the entire surface area of the sensor, leaving streaking marks for the entire sensor. They just so only happen to be noticeable under white and blue color range. White is simple to git rid of it, blue is a little bit more tricky.
  6. Miaow
    Miaow TPF Noob!
    May 25, 2007
    885
    South of Melbourne, Australia
    The 400D I know has a tin oxide sensor and needs eclipse E2
    This is the list of cameras that need Eclipse E2
    http://www.photosol.com/cameras_bymfg.html
  7. CanonSnob
    CanonSnob TPF Noob!
    May 25, 2007
    106
    Denver
    found a solution. Im just using a smooth skin texture file I made, and am doing a sample healing brush from that to the smeared photos.
  8. Rhubarb
    Rhubarb TPF Noob!
    Dec 16, 2004
    286
    Roaming the globe
    But what happened to your camera sensor?
  9. CanonSnob
    CanonSnob TPF Noob!
    May 25, 2007
    106
    Denver
    it got streaks on it from the cleaning solution when cleaning it.
  10. Rhubarb
    Rhubarb TPF Noob!
    Dec 16, 2004
    286
    Roaming the globe
    I realise that - but did you fix it?
