sensor cleaning
Discussion in 'Beyond the Basics' started by Keith Baran, Apr 8, 2009.
  1. Keith Baran
    Keith Baran TPF Noob!
    May 4, 2008
    29
    Nashville
    Hi everyone,
    I notice a small "hair" like particle in the lower right side of all my photos regardless of which lens I use. I have read many articles about cleaning the sensor on my camera. Reading them has created a great fear that I will screw something up and ruin my sensor.I have a Pentax K10. I would like to hear all suggestions. Thanks in advance for any advice.
    Keith
  2. adamwilliamking
    adamwilliamking TPF Noob!
    Feb 24, 2009
    481
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    There should be a sensor cleaning mode.
    Cleaning the sensor is just 'par for the course' when you own a DSLR. It's not hard to do and it's not as delicate as people seem to think. You are just cleaning a filter that sits on top of the sensor.
    Search the forum or use Google...it's easy to find sensor cleaning products and techniques.
  4. ismael
    ismael TPF Noob!
    May 10, 2003
    62
    My K100D has a cleanup feature in the menu. It jolts the sensor on power up and it is very effective. I suppose the K10D should have that as well. Check the menu on "settings" "sensor cleaning" or something like that. (I don't have the camera with me here) There are 2 options: mirror lockup and clean at power up.
    Hope this helps.
    Thanks,
  5. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    If sensor cleaning mode doesn't do it, remove the lens, raise the mirror and use a blower like a Giotto Rocket Blaster (the large sized one).
  6. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    This is the best method. Also turn your camera down so the dust falls out. And never use canned air it is usually notoriously dirty.
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    a) does raising the mirror mean opening the shutter or are you just blowing for blowing sake?
    b) This is a very bad idea! Firstly the sensor is exposing. Expose it to too much light while it's open and you're likely to damage it. Also while you're taking the exposure (I assume that's what could be meant by raising the mirror so ignore this if it isn't) the sensor is statically charged. So don't even bother trying to clean it while holding the shutter open and the mirror up in bulb mode.
    If automated sensor cleaning doesn't work all cameras have manual sensor cleaning options.
  8. tirediron
    Jul 8, 2005
    40,886
    12,415
    Victoria, BC
    I'm assuming Jerry was referring to the 'Raise mirror for sensor cleaning' mode on Nikons, which I assume has an equivalent on other bodies.
  9. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yeah just checking, because I have seen the "use bulb to raise mirror" suggested before.
  10. tirediron
    Jul 8, 2005
    40,886
    12,415
    Victoria, BC
    Ouch!
how do you lock mirror for clenaing with blower
how to raise mirror pentax dslr
