Sensor size question
Discussion in 'Photography Beginners' Forum' started by eccs19, Dec 22, 2009.
  1. eccs19
    eccs19 TPF Noob!
    Jun 30, 2008
    571
    6
    Lisle Ontario Canada
    A friend of mine just purchased a Panasonic LX3 camera, and in the manual it says that the sensor size is 1/1.63". He's always known sensor size by the actual physical size of the sensor (height & width). Anyone know the actual physical size of the sensor, or is it actually 1" x 1.63"? We figure that just doesn't sound correct. Did a Google, but only came up with the original number I posted.
  2. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    That is approximately a 6x8 millimeter sensor. This is a little larger than what I typically see in p&s's though not too much of a difference.
  3. Stosh
    Stosh TPF Noob!
    Jul 18, 2009
    203
    Lancaster, PA
  4. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    to further add, it's from the tv tube days... the 1/1.63 is the size of the sensor diagonally expressed as a function. Thus, the diagonal is 0.613 inches and the vertical and horizontal are appx. 1/4 x 1/3
  5. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  6. Martin_Garcia
    Martin_Garcia TPF Noob!
    Nov 23, 2009
    26
    Puerto Rico
    No, that number is the actual diameter of a circle. If you take 2/3 of this circle diameter you will get the actual diagonal of your sensor (average).
    Take a look at this Sensor Sizes: Camera System: Glossary: Learn: Digital Photography Review
    So, 1/1.63'' is about 0.61349'' converting this to mm (1 inch = 25.4 mm) we get a diameter of 15.58 mm. Now, this is not the real diagonal of your sensor. If you calculate the 2/3 of this circle diameter you will get you sensor diagonal. This is 10.389 mm aprox.
    Now to calculate the width and height of your sensor we need the aspect ratio that probably is 4:3. If this is the case the Width will be about 8.3112mm and the height 6.2334mm.
    Regards,
  7. Ron Evers
    Ron Evers Been spending a lot of time on here!
    Jun 28, 2008
    6,147
    2,017
    In the country just north of Toronto, Canada
  8. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    This non-standard, as the original Wiki link calls it, measurment dates from the ancient vacuum tube imagers using in TV cameras. The measurment is the diameter of the tube and not the dimension of the actual usable portion of the tube's face. The usable portion was approximately 2/3rds the diameter of the actual tube so the diagonal measure of the largest usable rectangle was about 2/3rds of the tube diameter.
  9. Otahyoni
    Otahyoni TPF Noob!
    Nov 14, 2009
    32
    Terre Haute, IN
    I looked up my sensor size. I was amazed at how small it actually is... wow...
