Shallow Depth of field help
Discussion in 'Beyond the Basics' started by Kryg, Oct 27, 2008.
  1. Kryg
    Kryg TPF Noob!
    Oct 16, 2008
    16
    I think I posted this on the wrong thread before so I'm reposting it here I think this is where it belongs
    Hello I’m having trouble shooting a photo with a shallow depth of field and cannot figure out what I’m doing wrong. I'm getting too much background the link is to one of my photos for an example. I'm using a Nikon D80 with a Tamron AF 18mm to 200mm lens 1:3.5-6.3. I have tried shooting with AF on and I’ve tried manual focus, F5.6, 1/200 and ISO of 200.
    http://farm4.static.flickr.com/3162/2979097390_ab47c5eafb_b.jpg
  2. tsaraleksi
    tsaraleksi TPF Noob!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    What focal length were you at? How far away were you from the subject? At f/5.6 you're going to be getting a fair amount of depth unless you are pretty close up on the subject, at maximum zoom.
  3. Kryg
    Kryg TPF Noob!
    Oct 16, 2008
    16
    75mm and about 15 feet away.
  4. tsaraleksi
    Jun 12, 2007
    1,045
    Greencastle Indiana
    There is nothing you can do with that lens and combination of factors to reduce your depth of field. You need to either use a much longer focal length and get further away, or use a lens with a much larger available f/stop.
  5. Mike_E
    Jan 26, 2007
    5,327
    266
    OK, it;'ll cost you about $120 delivered (Nikon 50mm f/1.8). Click the B&H or Adorama link at the top of the page.
    If you want extreme DoF then either save up for an f/1.2 or get an extension tube (the tube will give you an outrageously narrow DoF).
  6. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    You mean you are trying to blur the background to separate the subject from the background? Ideally you would use a lens with a larger aperture (like a zoom with a constant f2.8 or a prime with f1.8 or f1.4). But without changing your lens, try using a large aperture as possible (small f number), and bring the subject closer to the camera.
  7. Village Idiot
    Mar 20, 2008
    7,274
    406
    Online DOF calculator
    http://www.dofmaster.com/dofjs.html
    At a given focal length, the farther you are from a subject, the more DOF you will have. 70mm at 15' = about 2.75' DOF. 70mm at 1' distance (provided if that was possible) = .01' DOF.
    Now if you were to step back to about 40' and shoot at 300mm with f/5.6, you'd have 1.2" DOF because as you increase focal length, DOF changes. Try this and see if there is something you can do with that lens to get the desired result.
    DOF does not depend strictly on aperture. Play with the calculator a bit and you'll see.
    The below photo was shot at f/9 and has much less DOF. If the calculator is spot on shooting at 41mm, f/9 and 2' distance between the camera and me, then DOF is only .23. So about 1.2" of DOF, even at f/9.
    [​IMG]
  8. Kryg
    Kryg TPF Noob!
    Oct 16, 2008
    16
    Well I tried a shot at 32mm with f4.2 at about 6 inches a got the effect but that is to insanely close so I guess I’m going to have to buy a new lens. o well
  9. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    In other words, if the subject is closer to your camera, or if the background is farther away from the subject. You can still create the blur background type of photos. You just need to play around with it and see.
    And yes, check with the DoF calculator, it will give you a good idea how to create a blur background type photos.
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    You can't break the laws of physics... it's a combination of aperture vs distance between you and the subject vs the distance from camera behind the subject.
    You can get well blurred pictures with a small aperture, you just have to understand how it works:
    [​IMG]
    This picture was taken at F/7... yet both the foreground and background have good amounts of bokeh. What made this possible is that I was at 200mm. HERE is the supporting EXIF info from Flickr.
  11. beaminge36
    beaminge36 TPF Noob!
    Sep 17, 2008
    126
    Newark, NJ
    Separate your subject. In the example photo your shooting at the ground. If you put your pumpkin (im assuming that was your point of interest) on top of something and left 30 feet of space behind it and the background, the background would be far more blurred. You can achieve decent bokeh with a slower lens but you are limited to the scenarios that will produce that subject isolating blur.
    Nick
  12. mrodgers
    mrodgers No longer a newbie, moving up!
    Dec 13, 2007
    1,662
    7
    Hmm, pumpkin haphazardly laying in the yard along with the planter. Paper garbage laying about. Leaves scattered. Swingset and kid's toys laying around......
    Get yourself a longer lens. I don't want you in my yard taking pictures of my stuff. Go out on the public road with a longer lens if you want pictures of my yard!
    :mrgreen::lol::mrgreen:
