dxqcanada
- Joined
- Dec 4, 2008
- Messages
- 7,821
- Reaction score
- 1,673
- Location
- Woodbridge, Ontario, Canada
- Can others edit my Photos
- Photos OK to edit
I think I would blame the wide open aperture on that one also.
What does that mean?More than likely you are not stopping the lens down enough. Hard to say without example with exif data
Thanks... so increasing iso is better? I get so nervous because the noise make it look oof to me.... but i guess I'll be better off sbd may be adjusting luminance in lrWhat does that mean?More than likely you are not stopping the lens down enough. Hard to say without example with exif data
Stopping the lens down means using a smaller aperture (bigger f number). That 70-200mm f4 should be really sharp though, and it should be sharp wide open too, so I agree with dxqcanada, try using a shutter speed of at least 1/200 at 70mm.
What focus mode are you using? I've got a t5i and I have 3 modes. "one shot" which locks in the focus when you press the shutter half way, "AI Focus" which locks in the focus but will adjust it if your daughter moves, and "AI Servo" which continuously focuses for moving subjects. Try AI Focus and see if that helps.
Yes it is. Thank you. Ill try making iso higher to make aperature a larger numberIs the 70-200mm the f/4 version? If so, you are shooting it wide open as well. The version I had of that 70-200mm f/4.0 was soft at f/4 too.
I'm guessing the 50mm f/1.8 is not the STM (new) version either. I never could get the older versions of the 50mm f/1.8 to produce tack sharp photos at 1.8 either.
On my camera I have the AF button on the lowr right on the back. I bought David Busch Compact field guide for the T5i/700D. He may have one for the t6i or the t5i may be close enough for you. Great book for explaining everything about your camera. Better than the camera manual with big writing you can read.I know this is terrible.. but i have no idea what I'm using. I guess i Need to Google this! Thank you. So ai focus? Ill Google and see how to set this
Last one
1.8
50mm
800 iso
1/500 sec
