Sharpening in RAW dialog
Discussion in 'Graphics Programs and Photo Gallery' started by Rose, Apr 27, 2006.
  1. Rose
    Rose TPF Noob!
    Dec 14, 2005
    52
    Hi all
    Well i have just started shooting RAW with my canon 350D, using CS2.
    Was wondering how much people 'sharpen' in the raw dialog that comes up when u open your file in photoshop. As far as i can remember, its set 30 when you open it, but i usually increase to 40.
    ..I also use unsharp mask once i have done everything in photoshop, before saving or printing at these settings Amount 75% or more, Radius 0,6-1,5, Threshold 0-3 .
    Is this correct or can someone please give me more advice on sharpening with raw files..
    thank you in advance :wink:
  2. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Hi rose,
    For me it depends alot on what kind of photo your dealing with. If say i have a shot of a bird..... i'll use the sharpening in RAW to start with.... zooming right into the image to see whats happening..... im using a nikon plugin so it may not be exactly the same..... but generally the sharpening in raw helps, but doesnt give an obvious sharpened effect. I'll then use either unsharp-mask or smart sharpen to give the bird more detail after i'v adjusted levels etc.
    Other kinds of images are hard to tell..... most i dont want too sharp... i want soft or just medium, in which case i wont use any extra sharping in RAW or in ps. :)
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I don't recall what setting I use when opening the RAW file...I definitely don't increase it. I do my sharpening with USM when I'm done my other editing.
    As for the settings with USM...that's really variable. Everyone seems to use different numbers. I tend to adjust it by eye...some images need more...and some will start to look worse with too much.
    I often sharpen once then save the file. Then when I make a web version (reduce image size, save as JPEG) I sharpen again.
    Here are some examples I wrote down one time.
    "Polish"
    Amount 30%
    Radius 60
    Threshold 10
    "Subtle"
    85
  4. Rose
    Rose TPF Noob!
    Dec 14, 2005
    52
    thanks guys thats great - i do realise that it depends on the image, just wanted to make sure its ok sharpening twice so to speak -once in raw dialog and using USM! :thumbup:
  5. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Take the same photo, and run it through a couple of different workflows to see what works best for you.
    I was using the sharpening in CS2 Camera Raw at 30 to 40, but then I noticed it was causing nasty edge darkening effects in some of my photos. Particularly when the background is bright. I compared it to using USM alone, and the results were worlds better just using USM as the final step.
