shadowlands
- Joined
- Oct 9, 2009
- Messages
- 1,502
- Reaction score
- 383
- Location
- Houston, Texas
- Website
- www.flickr.com
- Can others edit my Photos
- Photos NOT OK to edit
Most excellent. Thanks big time, for taking the time.3D tracking is nice especially if there is only ONE subject you are tracking and it's a clear background. Different 3D tracking/AF systems will vary a bit on that. But in soccer (or whatever), if you use 3D tracking what subject is the camera going to initially focus on? If you are using a large aperture there could be a possibility that the real subject you want is OOF.Yes from all the above.
I learned long ago when doing sports on my D7000 that Single Point focus is the way to go. After all, you want to focus on ONE particular subject. The camera's computer doesn't know that. The camera wants to focus on the best contrast detected image out there. I learned that with the 70-300 nikon lens which, because of contrast issues, liked to focus on background fences and other subjects with more contrast. Nikon's also like the cross detection points in the middle of the frame (on the older AF systems).
The single focus point will give you focus on the subject that YOU want, not the camera's computer. You do have to keep your aim on the subject.
I also always use Manual Exposure because I want a particular Aperture and a particular Shutter Speed. You can use AP and SP but have to set those other limits to do what you want in your parameters.
ie, you want f/2.8 for subject isolation
and you want a high shutter speed to stop action.
you need both with AUTO ISO to control the ISO
Though one particular person here on TPF showed AP with parameters to counter if it got too bright the shutter would increase if the camera was at base ISO for a proper exposure.
Once I got all that and worked on my finger's ability to push the button half way my capture rate for in-focus shots skyrocketed. Many times I knew when I took a shot that was OOF before looking at it. (I have to Focus Acquire turned off)
As the action moved I also kept the focus throw short by focusing on the moving action but not taking a pic unless I wanted too. This minimized the focus throw distance for the lens and improved keepers once again.
I also try to get the action (primarily soccer) moving towards me. So I'm not in the "middle" of the sidelines but I try to be at the corners to get the action and faces coming towards me.
I appreciate the tips. Hey, 3D tracking is never mentioned. It's over-rated, I'm hearing? I will truly go back to single spot focus for sure. I believe that's what I did in the past with more success.
Auto ISO, note taken.
So Single Focus puts all the effort on the photographer. If you focus on the Subject that you want, then it's your finger, the lens focus speed, and how quickly you take the shot. Less things to go wrong, hopefully.
I'll on the filed tomorrow morning, hopefully with better results.
