sharpness of picture
Discussion in 'Beyond the Basics' started by shingfan, Jan 24, 2007.
  1. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    how do you make your picture more "3D" when shooting....how to achieve better sharpness...and "3D" feel?
  2. Peacemaker636
    Peacemaker636 TPF Noob!
    Jan 7, 2007
    156
    Iowa, U.S.
    Shallow depth of field, often created with a good macro lens (which also will make it very sharp), and a wide aperture.
  3. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Use a shorter focal length lens and get closer to the subject.
  4. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    3d effect is usually created by including foreground in the shot.
  5. GilTphoto
    GilTphoto TPF Noob!
    Jun 5, 2004
    28
    South Florida
    It depends on what you're shooting.
    If a landscape with both a close foreground object and a distant view, you need maximum DOF, so a small aperature is needed, such as f/22.
    If you want to isolate your subject and blur the background, you need a large aperature like f/2. This works well for wildlife as the subject may be moving and a large aperature will give you a fast shutter speed.
    If your subject is distant and stationary and you use a tripod, the shutter speed doesn't matter, so use the sweet spot of the lens which is the sharpest aperature usually in the middle
    f/5.6-f/8
    http://GilTphoto.com
  6. quackzed
    quackzed TPF Noob!
    Feb 1, 2007
    14
    there are a few things i've learned from painting that are used to give a flat surface "depth"
    1. perspective - things get smaller as they get farther away
    2. color- colors get more muted and cooler(bluer)the farther they are away(think of mountains and how they get lighter and lighter in the distance)due to the atmosphere and dust in the air etc...
    3. detail- we can see more detail up close than we can far away, try reading a newspaper at 10 feet...so edges get crisper the closer we are to something...
    4. contrast- things that are closer have a more dynamic contrast, this one and #2 are sort of the same thing... close up shadows are darker, highlights are brighter etc..
    so you can use this knowledge to 'push' the depth of your photos even further by..
    #1 choosing subjects that repeat at different depths and show how they get smaller...say a fence or road that goes off into the distance...
    #2 choosing reds and warm colors for the foreground to 'jump' forward, and cooler lighter backgrounds that 'recede'
    #3 choosing subjects with texture and detail for the foreground to take more advantage of the fact that detail and texture tell us something is close...
    #4 chose subjects in the foreground that have alot of dark darks and light lights and subjects in the background that are more limited in lightness and darkness...
    try not to think of these things as gimmicks, they arent. they are just a few of the things our brains just naturally get used to when looking at landscapes and outdoor scenes and anything else. it's these cues that help our brains figure out what it is were looking at, so we don't get disoriented by all the visual stimulus around us all the time.
    There, was that pretentious or what?! lol
  7. Mike_E
    Jan 26, 2007
    5,327
    266
    If you are talking about portraits, you might want to look into isolating your subject with more light which is also a slightly different color temp.
    mike
