Shoot before focus?
Discussion in 'Photography Beginners' Forum' started by kairo, Jun 25, 2008.
  1. kairo
    kairo TPF Noob!
    Jun 2, 2008
    8
    Reno, NV
    Howdy all.
    Is there a setting on the camera (Nikon D60) that will allow you to take a picture before the auto focus has locked onto a target? Reason I ask, is I wanted to shoot some pictures of the smoke that filled the valley in Reno yesterday, and the autofocus couldn't lock on exactly the way I wanted it. It kept hunting back and forth. I put it into manual mode and focused myself eventually.
    What I'd like to find (if it exists) is a way to take a picture whether the camera is focused or not.
  2. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    turn off autofocus and you can take unfocused pics all day long.
  3. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    :hail:
  4. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
    There really is no point to shoot unfocussed pictures, use manual just like you did already
  5. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    On my Canon camera, if I take it out of 'one shot' AF mode...then I can fire the shutter at any time. If I put it into one shot mode, it waits until the AF has locked onto something.
    I would assume your Nikon is similar.
  6. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    Rachel wins the prize.
    Why oh why do you want to take unfocused pictures?
  7. Village Idiot
    Mar 20, 2008
    7,274
    406
    He means using a mode like AI Servo that lets you fire without the focus lock so he can attempt to shoot when he thinks it's in focus while it's hunting. He is probably setup now to where the camera has to lock on a focus point before the shutter triggers, no matter how far down he's pushing the button.
    I'm sure there's a way to do it, but manually focusing is the best way to do it in that situation.
  8. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    Servo doesn't use the AF points right?
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Sure it does...it has to, there is no AF at all, without the AF point.
    The OP's problem was the the AF would not pick up the smoke that they wanted to focus on...they did not want an OOF image.
    In this case, manually focusing would be the way to go, as mentioned.
  10. djrichie28
    djrichie28 TPF Noob!
    Jan 24, 2008
    264
    7
    Waterloo, ON
    I'm guessing you have the focus mode set to "S" or Single. This mode usually doesn't allow you to fire your shot until it is locked. Try switching to "C" continuous. This mode should lets you fire away whenever you want. It will also keep focusing on your subject while you have the shutter half pressed. Helpful when your subject, or yourself is moving. I usually keep my camera set to 'C'
